Hello,
I've recently had some trouble with my router, which resulted in me factory resetting the modem and the router, which finally gave me the push to look through everything and see if it was running as it should.
I saw a message in the web interfalce telling mere there is a disk shortage. It didn't tell me much more than that. I've had a pihole running for some time, so it occured to me that this is the first time i've seen this message and there might be a problem that should be solved.
I tried to solve it myself, by following this post: Disk shortage (/var/log/pihole/FTL.log) ahead: 99% used
But the comments were going down a path that did not fit my problem, i think, since cron is running. I also tried looking through some of the other posts regarding the same problem, but it seems the problems are very unique/specific with this as a common symptom, which makes total sense.
I don't know what to do or look for. I've hopefully pasted output for 2 commands under this, correctly, which i think might be helpful.
pi@raspberrypi:/var/log $ journalctl -u cron
-- Logs begin at Fri 2023-07-07 18:49:54 BST, end at Fri 2023-07-07 20:35:10 BST. --
Jul 07 18:50:01 raspberrypi CRON[23105]: pam_unix(cron:session): session opened for user root by (uid=0)
Jul 07 18:50:01 raspberrypi CRON[23106]: pam_unix(cron:session): session opened for user pi by (uid=0)
Jul 07 18:50:01 raspberrypi CRON[23107]: (root) CMD ( PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker local)
Jul 07 18:50:01 raspberrypi CRON[23106]: pam_unix(cron:session): session closed for user pi
Jul 07 18:50:01 raspberrypi CRON[23105]: pam_unix(cron:session): session closed for user root
Jul 07 18:55:01 raspberrypi CRON[23156]: pam_unix(cron:session): session opened for user pi by (uid=0)
Jul 07 18:55:01 raspberrypi CRON[23157]: (pi) CMD (>/dev/null 2>&1)
Jul 07 18:55:01 raspberrypi CRON[23156]: pam_unix(cron:session): session closed for user pi
Jul 07 19:00:01 raspberrypi CRON[23189]: pam_unix(cron:session): session opened for user root by (uid=0)
Jul 07 19:00:01 raspberrypi CRON[23190]: pam_unix(cron:session): session opened for user pi by (uid=0)
Jul 07 19:00:01 raspberrypi CRON[23191]: (root) CMD ( PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker local)
Jul 07 19:00:01 raspberrypi CRON[23192]: (pi) CMD (>/dev/null 2>&1)
Jul 07 19:00:01 raspberrypi CRON[23190]: pam_unix(cron:session): session closed for user pi
Jul 07 19:00:01 raspberrypi CRON[23189]: pam_unix(cron:session): session closed for user root
Jul 07 19:05:01 raspberrypi CRON[23231]: pam_unix(cron:session): session opened for user pi by (uid=0)
Jul 07 19:05:01 raspberrypi CRON[23232]: (pi) CMD (>/dev/null 2>&1)
Jul 07 19:05:01 raspberrypi CRON[23231]: pam_unix(cron:session): session closed for user pi
Jul 07 19:09:01 raspberrypi CRON[23261]: pam_unix(cron:session): session opened for user root by (uid=0)
Jul 07 19:09:01 raspberrypi CRON[23262]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && if [ ! -d /run/systemd/system ]; then /usr/lib/php/sessionclean; fi)
Jul 07 19:09:01 raspberrypi CRON[23261]: pam_unix(cron:session): session closed for user root
Jul 07 19:10:01 raspberrypi CRON[23309]: pam_unix(cron:session): session opened for user root by (uid=0)
Jul 07 19:10:01 raspberrypi CRON[23310]: pam_unix(cron:session): session opened for user pi by (uid=0)
Jul 07 19:10:01 raspberrypi CRON[23311]: (root) CMD ( PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker local)
Jul 07 19:10:01 raspberrypi CRON[23312]: (pi) CMD (>/dev/null 2>&1)
Jul 07 19:10:01 raspberrypi CRON[23310]: pam_unix(cron:session): session closed for user pi
Jul 07 19:10:01 raspberrypi CRON[23309]: pam_unix(cron:session): session closed for user root
Jul 07 19:15:01 raspberrypi CRON[23359]: pam_unix(cron:session): session opened for user pi by (uid=0)
Jul 07 19:15:01 raspberrypi CRON[23360]: (pi) CMD (>/dev/null 2>&1)
Jul 07 19:15:01 raspberrypi CRON[23359]: pam_unix(cron:session): session closed for user pi
Jul 07 19:17:01 raspberrypi CRON[23377]: pam_unix(cron:session): session opened for user root by (uid=0)
Jul 07 19:17:01 raspberrypi CRON[23378]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Jul 07 19:17:01 raspberrypi CRON[23377]: pam_unix(cron:session): session closed for user root
Jul 07 19:20:01 raspberrypi CRON[23400]: pam_unix(cron:session): session opened for user root by (uid=0)
Jul 07 19:20:01 raspberrypi CRON[23401]: pam_unix(cron:session): session opened for user pi by (uid=0)
Jul 07 19:20:01 raspberrypi CRON[23402]: (root) CMD ( PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker local)
Jul 07 19:20:01 raspberrypi CRON[23403]: (pi) CMD (>/dev/null 2>&1)
Jul 07 19:20:02 raspberrypi CRON[23401]: pam_unix(cron:session): session closed for user pi
Jul 07 19:20:02 raspberrypi CRON[23400]: pam_unix(cron:session): session closed for user root
Jul 07 19:25:01 raspberrypi CRON[23492]: pam_unix(cron:session): session opened for user pi by (uid=0)
Jul 07 19:25:01 raspberrypi CRON[23493]: (pi) CMD (>/dev/null 2>&1)
Jul 07 19:25:01 raspberrypi CRON[23492]: pam_unix(cron:session): session closed for user pi
Jul 07 19:27:01 raspberrypi CRON[23518]: pam_unix(cron:session): session opened for user root by (uid=0)
Jul 07 19:27:01 raspberrypi CRON[23519]: (root) CMD ( PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote)
Jul 07 19:27:01 raspberrypi CRON[23518]: pam_unix(cron:session): session closed for user root
Jul 07 19:30:01 raspberrypi CRON[23573]: pam_unix(cron:session): session opened for user root by (uid=0)
Jul 07 19:30:01 raspberrypi CRON[23574]: pam_unix(cron:session): session opened for user pi by (uid=0)
Jul 07 19:30:01 raspberrypi CRON[23575]: (root) CMD ( PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker local)
Jul 07 19:30:01 raspberrypi CRON[23576]: (pi) CMD (>/dev/null 2>&1)
pi@raspberrypi:/var/log $ ls -lS
total 40288
-rw-r--r-- 1 pihole pihole 18173952 Jul 7 07:52 pihole.log
-rw-r--r-- 1 pihole pihole 17128456 Jun 6 2022 pihole.log.1
-rw-r--r-- 1 pihole pihole 898189 Jun 2 2022 pihole.log.5.gz
-rw-r--r-- 1 pihole pihole 877462 Jun 3 2022 pihole.log.4.gz
-rw-r--r-- 1 pihole pihole 846682 Jun 5 2022 pihole.log.2.gz
-rw-r----- 1 root adm 702909 Jun 5 2022 auth.log.1
-rw-r--r-- 1 pihole pihole 673931 Jun 4 2022 pihole.log.3.gz
-rw-r----- 1 root adm 362057 Jun 5 2022 daemon.log.1
-rw-rw-r-- 1 root utmp 292292 Jul 7 19:58 lastlog
-rw-r----- 1 root adm 188416 Jul 7 20:35 auth.log
-rw-r----- 1 root adm 114688 Jul 7 20:38 daemon.log
-rw-r----- 1 root adm 110592 Jul 7 20:38 syslog
-rw-r----- 1 root adm 102487 Jun 6 2022 syslog.1
-rw-r--r-- 1 root pihole 73728 Jul 7 20:24 pihole_debug.log
-rw-r--r-- 1 root root 56906 Jul 6 23:55 log2ram.log
-rw-rw-r-- 1 root utmp 49152 Jul 7 19:58 wtmp
-rw-r----- 1 root adm 37576 May 29 2022 auth.log.2.gz
-rw-r----- 1 root adm 36522 May 15 2022 auth.log.4.gz
-rw-r----- 1 root adm 36147 May 22 2022 auth.log.3.gz
-rw-r----- 1 root adm 34230 Apr 19 2022 kern.log.1
-rw-r----- 1 root adm 30432 Feb 4 2022 kern.log.4.gz
-rw-r----- 1 root adm 28068 May 29 2022 daemon.log.2.gz
-rw-r----- 1 root adm 26858 May 22 2022 daemon.log.3.gz
-rw-r----- 1 root adm 26857 May 15 2022 daemon.log.4.gz
-rw-r--r-- 1 root root 24000 Apr 28 2022 faillog
-rw-r--r-- 1 root root 17013 May 30 2022 dpkg.log.1
-rw-r--r-- 1 pihole pihole 12288 Jul 7 20:37 pihole-FTL.log
-rw-r----- 1 root adm 8647 May 31 2022 syslog.7.gz
-rw-r----- 1 root adm 8510 Jun 2 2022 syslog.5.gz
-rw-r----- 1 root adm 8390 Jun 3 2022 syslog.4.gz
-rw-r----- 1 root adm 8298 Jun 5 2022 syslog.2.gz
-rw-r----- 1 root adm 8288 Jun 4 2022 syslog.3.gz
-rw-r----- 1 root adm 8251 Jun 1 2022 syslog.6.gz
-rw-r----- 1 root adm 8222 Feb 22 2022 kern.log.3.gz
-rw-r--r-- 1 root root 5283 Oct 25 2021 dpkg.log.7.gz
-rw-r--r-- 1 root root 5174 Apr 29 2022 dpkg.log.2.gz
-rw-r--r-- 1 root root 4096 Jun 27 00:01 dpkg.log
-rw-r----- 1 root adm 4096 Jul 7 20:38 messages
-rw-r----- 1 root adm 4096 Jun 30 12:17 openvpn.log
-rw-r----- 1 root adm 3465 May 25 2022 openvpn.log.1
-rw-r--r-- 1 root root 2776 Mar 31 2022 dpkg.log.3.gz
-rw-r--r-- 1 root root 2122 Jan 31 2022 dpkg.log.5.gz
-rw-r--r-- 1 root root 2122 Nov 9 2021 dpkg.log.6.gz
-rw-r--r-- 1 root root 1753 Jun 5 2022 log2ram.log.1
-rw-r----- 1 root adm 1667 Jun 5 2022 messages.1
-rw-r--r-- 1 pihole pihole 1580 Jun 6 2022 pihole-FTL.log.1
-rw-r----- 1 root adm 1461 Apr 19 2022 debug.1
-rw-r--r-- 1 root root 988 Feb 27 2022 dpkg.log.4.gz
-rw-r----- 1 root adm 928 Apr 30 2022 openvpn.log.2.gz
-rw-r----- 1 root adm 822 Feb 4 2022 debug.3.gz
-rw-r----- 1 root adm 807 Feb 22 2022 openvpn.log.4.gz
-rw-r----- 1 root adm 805 Apr 19 2022 openvpn.log.3.gz
-rw-r----- 1 root adm 581 Nov 16 2021 debug.4.gz
drwxr-x--- 2 www-data www-data 560 Jul 2 00:00 lighttpd
-rw-r----- 1 root adm 463 Feb 22 2022 debug.2.gz
-rw-r--r-- 1 root root 442 Jun 1 2022 log2ram.log.5.gz
drwxr-xr-x 2 root root 420 Jun 30 12:17 apt
-rw-r----- 1 root adm 374 May 28 2022 user.log.1
-rw-r--r-- 1 pihole pihole 362 Jun 4 2022 pihole-FTL.log.3.gz
-rw-r--r-- 1 root root 359 Mar 29 2022 alternatives.log.4.gz
-rw-r--r-- 1 root root 358 Jun 4 2022 log2ram.log.2.gz
-rw-r--r-- 1 root root 357 May 30 2022 log2ram.log.7.gz
-rw-r--r-- 1 pihole pihole 347 Jun 5 2022 pihole-FTL.log.2.gz
-rw-r--r-- 1 root root 321 Apr 20 2022 alternatives.log.3.gz
-rw-r--r-- 1 root root 315 May 31 2022 log2ram.log.6.gz
-rw-r--r-- 1 root root 314 Jun 3 2022 log2ram.log.3.gz
-rw-r--r-- 1 root root 314 Jun 2 2022 log2ram.log.4.gz
-rw-r----- 1 root adm 295 May 29 2022 messages.2.gz
-rw-r--r-- 1 root root 277 Oct 18 2021 alternatives.log.6.gz
-rw-r--r-- 1 root root 253 Jun 4 2022 alternatives.log.1
drwxr-xr-x 2 root root 240 Jul 7 00:00 cups
-rw-r--r-- 1 root root 213 Nov 9 2021 alternatives.log.5.gz
drwxr-x--- 2 root adm 200 Jul 1 06:54 unattended-upgrades
-rw-r----- 1 root adm 194 May 22 2022 messages.3.gz
-rw-r----- 1 root adm 193 May 15 2022 messages.4.gz
-rw-r----- 1 root adm 192 Feb 25 2022 kern.log.2.gz
-rw-r--r-- 1 root root 161 Apr 28 2022 alternatives.log.2.gz
drwxr-xr-x 2 root root 40 Apr 28 2021 openvpn
drwx------ 2 root root 40 May 7 2021 private
-rw-r--r-- 1 root root 0 Jun 27 00:01 alternatives.log
-rw-r--r-- 1 root root 0 May 7 2021 bootstrap.log
-rw-rw---- 1 root utmp 0 Jul 1 00:00 btmp
-rw-rw---- 1 root utmp 0 Jun 1 00:00 btmp.1
-rw-r----- 1 root adm 0 Jun 30 12:17 debug
-rw-r----- 1 root adm 0 Jun 30 12:17 kern.log
-rw------- 1 root root 0 Jul 7 20:38 openvpn-status.log
-rw-r--r-- 1 root root 0 Jul 2 03:36 pihole_updateGravity.log
-rw-r----- 1 root adm 0 Apr 2 13:43 user.log
I expect the logs to be cleared at a fitting rate.
pi@raspberrypi:/var/log $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
pi@raspberrypi:/var/log $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 29G 3.0G 25G 11% /
devtmpfs 1.8G 0 1.8G 0% /dev
tmpfs 1.9G 2.5M 1.9G 1% /dev/shm
tmpfs 1.9G 217M 1.7G 12% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/mmcblk0p1 253M 49M 204M 20% /boot
log2ram 40M 40M 0 100% /var/log
tmpfs 384M 0 384M 0% /run/user/999
tmpfs 384M 0 384M 0% /run/user/1000
I get a message telling me there is a disk shortage. I am not sure if it is normal and i just havent noticed, or if there is a problem and how to solve it.
