I have RPi 2b running standard setup pi hole.
I am getting this error
Unable to build gravity tree in /etc/pihole/gravity.db_temp
Error: stepping, database or disk is full (13)
[✗] Unable to create database. Please contact support.
My debug log is as follows
*** [ INITIALIZING ]
[i] 2022-05-20:17:04:01 debug log has been initialized.
[i] System has been running for 0 days, 3 hours, 25 minutes
[i] Core: v5.10 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Remotes: origin https://github.com/pi-hole/pi-hole.git (fetch)
origin https://github.com/pi-hole/pi-hole.git (push)
[i] Branch: master
[i] Commit: v5.10-0-g853f6b7d
[i] Web: v5.12 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Remotes: origin https://github.com/pi-hole/AdminLTE.git (fetch)
origin https://github.com/pi-hole/AdminLTE.git (push)
[i] Branch: master
[i] Commit: v5.12-0-g6c320a42
[✓] FTL: v5.15
[i] 1.4.59
[i] 7.4.28
[i] dig return code: 0
[i] dig response: "Raspbian=9,10,11 Ubuntu=16,18,20,21 Debian=9,10,11 Fedora=33,34 CentOS=7,8"
[✓] Distro: Raspbian
[✓] Version: 11
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: FirewallD
[i] Firewalld service inactive
*** [ DIAGNOSING ]: Processor
[✓] armv6l
*** [ DIAGNOSING ]: Disk usage
Filesystem Size Used Avail Use% Mounted on
/dev/root 7.0G 3.3G 3.4G 50% /
devtmpfs 87M 0 87M 0% /dev
tmpfs 215M 1.2M 214M 1% /dev/shm
tmpfs 86M 704K 86M 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
none 1.0M 0 1.0M 0% /var/tmp
/dev/mmcblk0p1 253M 50M 203M 20% /boot
tmpfs 43M 20K 43M 1% /run/user/1000
tmpfs 43M 16K 43M 1% /run/user/999
*** [ DIAGNOSING ]: Network interfaces and addresses
inet6 ::1/128 scope host
2: enxb827eb01a50a: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:01:a5:0a brd ff:ff:ff:ff:ff:ff
inet 192.168.1.200/24 brd 192.168.1.255 scope global noprefixroute enxb827eb01a50a
inet6 2a00:23c4:e1c5:8a01:5f86:4412:d6d6:a8ff/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 257sec preferred_lft 77sec
inet6 fe80::322d:fb7d:805f:475d/64 scope link
*** [ DIAGNOSING ]: Network routing table
default via 192.168.1.254 dev enxb827eb01a50a src 192.168.1.200 metric 202
192.168.1.0/24 dev enxb827eb01a50a proto dhcp scope link src 192.168.1.200 metric 202
[✓] IPv4 address(es) bound to the enxb827eb01a50a interface:
192.168.1.200/24
[✓] IPv6 address(es) bound to the enxb827eb01a50a interface:
[i] Default IPv4 gateway: 192.168.1.254
* Pinging 192.168.1.254...
[✓] Gateway responded.
[i] Default IPv6 gateway: fe80::c6e5:32ff:fe7d:9133
* Pinging fe80::c6e5:32ff:fe7d:9133...
[✓] udp:0.0.0.0:53 is in use by pihole-FTL
udp:0.0.0.0:68 is in use by dhcpcd
udp:0.0.0.0:48801 is in use by avahi-daemon
udp:0.0.0.0:5353 is in use by avahi-daemon
[✓] udp:*:53 is in use by pihole-FTL
udp:*:53200 is in use by avahi-daemon
udp:*:5353 is in use by avahi-daemon
udp:*:546 is in use by dhcpcd
[✓] tcp:0.0.0.0:80 is in use by lighttpd
[✓] tcp:0.0.0.0:53 is in use by pihole-FTL
tcp:0.0.0.0:22 is in use by sshd
[✓] tcp:127.0.0.1:4711 is in use by pihole-FTL
[✓] tcp:*:80 is in use by lighttpd
[✓] tcp:*:53 is in use by pihole-FTL
tcp:*:22 is in use by sshd
[✓] tcp:[::1]:4711 is in use by pihole-FTL
[✓] us.clickintext.net is 0.0.0.0 on lo (127.0.0.1)
[✓] us.clickintext.net is 0.0.0.0 on enxb827eb01a50a (192.168.1.200)
[✓] doubleclick.com is 172.217.169.14 via a remote, public DNS server (8.8.8.8)
[✓] www.d2v81tfe2x14j0.cloudfront.net is :: on lo (::1)
[✓] www.d2v81tfe2x14j0.cloudfront.net is :: on enxb827eb01a50a (2a00:23c4:e1c5:8a01:5f86:4412:d6d6:a8ff)
[✓] www.d2v81tfe2x14j0.cloudfront.net is :: on enxb827eb01a50a (fe80::322d:fb7d:805f:475d)
[✓] doubleclick.com is 2a00:1450:4009:81d::200e via a remote, public DNS server (2001:4860:4860::8888)
Timeout: 10 seconds
* Received 350 bytes from enxb827eb01a50a:192.168.1.254
Offered IP address: 192.168.1.200
Server IP address: 192.168.1.254
Relay-agent IP address: N/A
BOOTP server: (empty)
BOOTP file: (empty)
DHCP options:
Message type: DHCPOFFER (2)
server-identifier: 192.168.1.254
lease-time: 86400 ( 1d )
renewal-time: 43200 ( 12h )
rebinding-time: 75600 ( 21h )
netmask: 255.255.255.0
broadcast: 192.168.1.255
domain-name: "home"
dns-server: 192.168.1.254
router: 192.168.1.254
wpad-server: "
--- end of options ---
DHCP packets received on interface enxb827eb01a50a: 1
[✓] lighttpd daemon is active
*** [ DIAGNOSING ]: Pi-hole-FTL full status
Active: active (exited) since Fri 2022-05-20 17:02:11 BST; 2min 55s ago
Process: 10499 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
CPU: 550ms
May 20 17:02:07 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
May 20 17:02:08 raspberrypi pihole-FTL[10499]: Not running
May 20 17:02:08 raspberrypi su[10511]: (to pihole) root on none
May 20 17:02:08 raspberrypi su[10511]: pam_unix(su:session): session opened for user pihole(uid=999) by (uid=0)
May 20 17:02:11 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
DNSSEC=false
REV_SERVER=true
REV_SERVER_CIDR=192.168.1.1/24
REV_SERVER_TARGET=192.168.1.254
REV_SERVER_DOMAIN=local
BLOCKING_ENABLED=true
PIHOLE_INTERFACE=enxb827eb01a50a
IPV4_ADDRESS=192.168.1.200/24
IPV6_ADDRESS=fde6:4571:c068:0:b0d4:ef2c:5b19:4976
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
CACHE_SIZE=10000
DNS_FQDN_REQUIRED=true
DNS_BOGUS_PRIV=true
DNSMASQ_LISTENING=local
PIHOLE_DNS_1=1.1.1.1
PIHOLE_DNS_2=1.0.0.1
HTTP/1.1 200 OK
Expires: Fri, 20 May 2022 16:05:11 GMT
Cache-Control: max-age=0
Date: Fri, 20 May 2022 16:05:11 GMT
Server: lighttpd/1.4.59
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
*** [ DIAGNOSING ]: Gravity Database
-rw-rw-r-- 1 pihole pihole 61M May 20 16:57 /etc/pihole/gravity.db
*** [ DIAGNOSING ]: Info table
property value
version 15
updated 1643888065
gravity_count 958195
Last gravity run finished at: Thu Feb 3 11:34:25 GMT 2022
----- First 10 Gravity Domains -----
localhost.localdomain
wizhumpgyros.com
wizhumpgyros.com
coccyxwickimp.com
coccyxwickimp.com
n2019cov.000webhostapp.com
webmail-who-int.000webhostapp.com
*** [ DIAGNOSING ]: Groups
id enabled name date_added date_modified description
0 1 Default 2022-02-03 01:17:17 2022-02-03 01:17:17 The default group
1 1 New 2022-02-03 03:28:06 2022-02-03 03:28:06 Test
*** [ DIAGNOSING ]: Clients
id group_ids ip date_added date_modified comment
1 0,1 20:CF:30:CC:72:8E 2022-02-03 05:07:51 2022-02-03 05:08:06
2 0,1 DC:A6:32:04:D1:4C 2022-02-03 05:08:18 2022-02-03 10:38:10
*** [ DIAGNOSING ]: Adlists
id enabled group_ids address date_added date_modified comment
1 1 0,1 https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts 2022-02-03 01:17:17 2022-02-03 11:27:25 Migrated from /etc/pihole/adlists.list
2 1 0,1 https://blocklistproject.github.io/Lists/tracking.txt 2022-02-03 02:02:17 2022-02-03 11:27:28 Tracking
3 1 0,1 https://blocklistproject.github.io/Lists/scam.txt 2022-02-03 02:02:50 2022-02-03 11:27:33 Scam
4 1 0,1 https://blocklistproject.github.io/Lists/redirect.txt 2022-02-03 02:03:35 2022-02-03 11:29:59 Redirect
5 1 0,1 https://blocklistproject.github.io/Lists/ransomware.txt 2022-02-03 02:04:00 2022-02-03 11:30:02 Ransomware
6 0 0,1 https://blocklistproject.github.io/Lists/piracy.txt 2022-02-03 02:04:24 2022-05-20 16:57:02 Piracy
7 0 0,1 https://blocklistproject.github.io/Lists/phishing.txt 2022-02-03 02:04:44 2022-05-20 16:56:48 Phishing
8 0 0,1 https://blocklistproject.github.io/Lists/malware.txt 2022-02-03 02:05:17 2022-05-20 16:56:45 Malware
9 1 0,1 https://blocklistproject.github.io/Lists/ads.txt 2022-02-03 02:05:58 2022-02-03 11:30:19 ads
10 1 0,1 https://raw.githubusercontent.com/kboghdady/youTube_ads_4_pi-hole/master/crowed_list.txt 2022-02-03 02:08:10 2022-02-03 11:30:23 YouTube Ads
12 0 0,1 https://raw.githubusercontent.com/danielcuthbert/thescum/master/dailyexpress_web.csv 2022-02-03 04:52:47 2022-05-20 16:57:51 dailyexpress_web
13 0 0,1 https://raw.githubusercontent.com/danielcuthbert/thescum/master/dailymail_web.csv 2022-02-03 04:53:15 2022-05-20 16:57:48 dailymail_web
14 0 0,1 https://raw.githubusercontent.com/danielcuthbert/thescum/master/telegraph_web.csv 2022-02-03 04:53:48 2022-05-20 16:57:46 telegraph_web
15 0 0,1 https://raw.githubusercontent.com/danielcuthbert/thescum/master/thesun_web.csv 2022-02-03 04:54:14 2022-05-20 16:57:42 thesun_web
-rw-r--r-- 1 root root 0 Feb 3 01:16 /etc/pihole/custom.list
-rw-r--r-- 1 root root 65 May 20 16:59 /etc/pihole/local.list
-rw-r--r-- 1 root root 234 Feb 3 01:16 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-rw-r-- 1 pihole root 163 May 20 17:02 /etc/pihole/pihole-FTL.conf
CHECK_LOAD=false
PRIVACYLEVEL=0
RATE_LIMIT=1000/60
-rw-r--r-- 1 root root 1.5K May 20 17:02 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
log-async
server=1.1.1.1
server=1.0.0.1
domain-needed
expand-hosts
bogus-priv
local-service
rev-server=192.168.1.1/24,192.168.1.254
server=/local/192.168.1.254
-rw-r--r-- 1 root root 2.2K May 20 16:01 /etc/dnsmasq.d/06-rfc6761.conf
server=/test/
server=/localhost/
server=/invalid/
server=/bind/
server=/onion/
-rw-r--r-- 1 root root 0 Feb 3 01:16 /etc/lighttpd/external.conf
-rw-r--r-- 1 root root 3.9K May 20 16:01 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "/pihole/index.php"
server.pid-file = "/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
server.stream-response-body = 1
mimetype.assign = (
".ico" => "image/x-icon",
".jpeg" => "image/jpeg",
".jpg" => "image/jpeg",
".png" => "image/png",
".svg" => "image/svg+xml",
".html" => "text/html; charset=utf-8",
".js" => "text/javascript; charset=utf-8",
".json" => "application/json; charset=utf-8",
".map" => "application/json; charset=utf-8",
".txt" => "text/plain; charset=utf-8",
".eot" => "application/vnd.ms-fontobject",
".otf" => "font/otf",
".ttc" => "font/collection",
".ttf" => "font/ttf",
".woff" => "font/woff",
".woff2" => "font/woff2"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
url.access-deny = ("")
$HTTP["url"] =~ "/(teleporter|api_token)\.php$" {
$HTTP["referer"] =~ "/admin/settings\.php" {
setenv.add-response-header = ( "X-Frame-Options" => "SAMEORIGIN" )
expire.url = ( "" => "access plus 0 seconds" )
-rw-r--r-- 1 root root 1.8K May 20 16:01 /etc/cron.d/pihole
26 3 * * 7 root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole flush once quiet
@reboot root /usr/sbin/logrotate --state /var/lib/logrotate/pihole /etc/pihole/logrotate
*/10 * * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker local
6 13 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 298 May 20 16:02 /var/log/lighttpd/error.log
-----head of error.log------
2022-05-20 13:39:42: server.c.1787) logfiles cycled UID = 0 PID = 778
2022-05-20 16:02:01: server.c.1976) server stopped by UID = 0 PID = 1
2022-05-20 16:02:07: server.c.1513) server started (lighttpd/1.4.59)
2022-05-20 16:02:07: configfile.c.1142) WARNING: unknown config-key: alias.url (ignored)
-----tail of error.log------
-rw-r--r-- 1 pihole pihole 6.1K May 20 17:02 /var/log/pihole-FTL.log
[2022-05-20 17:02:10.801 10515M] Using log file /var/log/pihole-FTL.log
[2022-05-20 17:02:10.802 10515M] ########## FTL started on raspberrypi! ##########
[2022-05-20 17:02:10.803 10515M] FTL branch: master
[2022-05-20 17:02:10.803 10515M] FTL version: v5.15
[2022-05-20 17:02:10.805 10515M] FTL commit: 4bb0bfe
[2022-05-20 17:02:10.806 10515M] FTL date: 2022-04-20 19:35:19 +0100
[2022-05-20 17:02:10.806 10515M] FTL user: pihole
[2022-05-20 17:02:10.808 10515M] Compiled for armv6hf (compiled on CI) using arm-linux-gnueabihf-gcc (crosstool-NG crosstool-ng-1.22.0-88-g8460611) 4.9.3
[2022-05-20 17:02:10.811 10515M] Creating mutex
[2022-05-20 17:02:10.812 10515M] Creating mutex
[2022-05-20 17:02:10.827 10515M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2022-05-20 17:02:10.828 10515M] SOCKET_LISTENING: only local
[2022-05-20 17:02:10.828 10515M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2022-05-20 17:02:10.829 10515M] MAXDBDAYS: max age for stored queries is 365 days
[2022-05-20 17:02:10.829 10515M] RESOLVE_IPV6: Resolve IPv6 addresses
[2022-05-20 17:02:10.830 10515M] RESOLVE_IPV4: Resolve IPv4 addresses
[2022-05-20 17:02:10.830 10515M] DBINTERVAL: saving to DB file every minute
[2022-05-20 17:02:10.830 10515M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2022-05-20 17:02:10.831 10515M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2022-05-20 17:02:10.831 10515M] PRIVACYLEVEL: Set to 0
[2022-05-20 17:02:10.832 10515M] IGNORE_LOCALHOST: Show queries from localhost
[2022-05-20 17:02:10.832 10515M] BLOCKINGMODE: Null IPs for blocked domains
[2022-05-20 17:02:10.833 10515M] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2022-05-20 17:02:10.833 10515M] DBIMPORT: Importing history from database
[2022-05-20 17:02:10.834 10515M] PIDFILE: Using /run/pihole-FTL.pid
[2022-05-20 17:02:10.834 10515M] PORTFILE: Using /run/pihole-FTL.port
[2022-05-20 17:02:10.835 10515M] SOCKETFILE: Using /run/pihole/FTL.sock
[2022-05-20 17:02:10.836 10515M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2022-05-20 17:02:10.836 10515M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2022-05-20 17:02:10.837 10515M] GRAVITYDB: Using /etc/pihole/gravity.db
[2022-05-20 17:02:10.837 10515M] PARSE_ARP_CACHE: Active
[2022-05-20 17:02:10.838 10515M] CNAME_DEEP_INSPECT: Active
[2022-05-20 17:02:10.838 10515M] DELAY_STARTUP: No delay requested.
[2022-05-20 17:02:10.840 10515M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2022-05-20 17:02:10.840 10515M] NICE: Set process niceness to -10 (default)
[2022-05-20 17:02:10.856 10515M] PIHOLE_PTR: internal PTR generation enabled (pi.hole)
[2022-05-20 17:02:10.857 10515M] ADDR2LINE: Enabled
[2022-05-20 17:02:10.858 10515M] REPLY_WHEN_BUSY: Permit queries when the database is busy
[2022-05-20 17:02:10.859 10515M] BLOCK_TTL: 2 seconds
[2022-05-20 17:02:10.859 10515M] BLOCK_ICLOUD_PR: Enabled
[2022-05-20 17:02:10.860 10515M] CHECK_LOAD: Disabled
[2022-05-20 17:02:10.861 10515M] CHECK_SHMEM: Warning if shared-memory usage exceeds 90%
[2022-05-20 17:02:10.864 10515M] CHECK_DISK: Warning if certain disk usage exceeds 90%
[2022-05-20 17:02:10.867 10515M] Finished config file parsing
[2022-05-20 17:02:10.884 10515M] Database version is 12
[2022-05-20 17:02:10.884 10515M] Resizing "FTL-strings" from 40960 to (81920 * 1) == 81920 (/dev/shm: 1.1MB used, 225.3MB total, FTL uses 1.1MB)
[2022-05-20 17:02:10.888 10515M] Imported 0 alias-clients
[2022-05-20 17:02:10.889 10515M] Database successfully initialized
[2022-05-20 17:02:10.962 10515M] New upstream server: 1.1.1.1:53 (0/256)
[2022-05-20 17:02:11.150 10515M] New upstream server: 1.0.0.1:53 (1/256)
[2022-05-20 17:02:11.186 10515M] Imported 1872 queries from the long-term database
[2022-05-20 17:02:11.188 10515M] -> Total DNS queries: 1872
[2022-05-20 17:02:11.188 10515M] -> Cached DNS queries: 44
[2022-05-20 17:02:11.189 10515M] -> Forwarded DNS queries: 418
[2022-05-20 17:02:11.189 10515M] -> Blocked DNS queries: 1401
[2022-05-20 17:02:11.189 10515M] -> Unknown DNS queries: 0
[2022-05-20 17:02:11.189 10515M] -> Unique domains: 105
[2022-05-20 17:02:11.190 10515M] -> Unique clients: 2
[2022-05-20 17:02:11.190 10515M] -> Known forward destinations: 2
[2022-05-20 17:02:11.190 10515M] Successfully accessed setupVars.conf
[2022-05-20 17:02:11.208 10515M] listening on 0.0.0.0 port 53
[2022-05-20 17:02:11.208 10515M] listening on :: port 53
[2022-05-20 17:02:11.274 10518M] PID of FTL process: 10518
[2022-05-20 17:02:11.281 10518M] INFO: FTL is running as user pihole (UID 999)
[2022-05-20 17:02:11.319 10518/T10519] Listening on port 4711 for incoming IPv4 telnet connections
[2022-05-20 17:02:11.331 10518/T10521] Listening on Unix socket
[2022-05-20 17:02:11.356 10518/T10520] Listening on port 4711 for incoming IPv6 telnet connections
[2022-05-20 17:02:11.376 10518M] Reloading DNS cache
[2022-05-20 17:02:11.538 10518/T10522] Compiled 0 whitelist and 0 blacklist regex filters for 2 clients in 42.0 msec
[2022-05-20 17:02:11.539 10518/T10522] Blocking status is enabled
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 pihole pihole 668K May 20 17:04 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 240 May 20 17:02 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 4.0K May 20 17:02 /dev/shm/FTL-dns-cache
-rw------- 1 pihole pihole 20K May 20 17:02 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 56 May 20 17:02 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 12K May 20 17:02 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 4.0K May 20 17:02 /dev/shm/FTL-per-client-regex
-rw------- 1 pihole pihole 176K May 20 17:02 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 12 May 20 17:02 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 80K May 20 17:02 /dev/shm/FTL-strings
-rw------- 1 pihole pihole 156K May 20 17:02 /dev/shm/FTL-upstreams
-rw-r--r-- 1 root root 24 May 20 16:01 /etc/dnsmasq.conf
conf-dir=/etc/dnsmasq.d
-rw-r--r-- 1 root root 91 Feb 14 15:02 /etc/resolv.conf
search home
nameserver fe80::c6e5:32ff:fe7d:9133%enxb827eb01a50a
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
*** [ DIAGNOSING ]: Locale
LANG=
-rw-r--r-- 1 pihole pihole 6.1K May 20 17:04 /var/log/pihole.log
-----head of pihole.log------
May 20 17:02:11 dnsmasq[10518]: started, version pi-hole-2.87test8 cachesize 10000
May 20 17:02:11 dnsmasq[10518]: DNS service limited to local subnets
May 20 17:02:11 dnsmasq[10518]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN DHCP DHCPv6 Lua TFTP no-conntrack ipset no-nftset auth cryptohash DNSSEC loop-detect inotify dumpfile
May 20 17:02:11 dnsmasq[10518]: using nameserver 1.1.1.1#53
May 20 17:02:11 dnsmasq[10518]: using nameserver 1.0.0.1#53
May 20 17:02:11 dnsmasq[10518]: using nameserver 192.168.1.254#53 for domain 1.168.192.in-addr.arpa
May 20 17:02:11 dnsmasq[10518]: using nameserver 192.168.1.254#53 for domain local
May 20 17:02:11 dnsmasq[10518]: using only locally-known addresses for onion
May 20 17:02:11 dnsmasq[10518]: using only locally-known addresses for bind
May 20 17:02:11 dnsmasq[10518]: using only locally-known addresses for invalid
May 20 17:02:11 dnsmasq[10518]: using only locally-known addresses for localhost
May 20 17:02:11 dnsmasq[10518]: using only locally-known addresses for test
May 20 17:02:11 dnsmasq[10518]: read /etc/hosts - 12 addresses
May 20 17:02:11 dnsmasq[10518]: read /etc/pihole/custom.list - 0 addresses
May 20 17:02:11 dnsmasq[10518]: read /etc/pihole/local.list - 0 addresses
May 20 17:02:54 dnsmasq[10518]: query[AAAA] b-graph.facebook.com from 192.168.1.5
May 20 17:02:54 dnsmasq[10518]: forwarded b-graph.facebook.com to 1.1.1.1
May 20 17:02:54 dnsmasq[10518]: forwarded b-graph.facebook.com to 1.0.0.1
May 20 17:02:54 dnsmasq[10518]: query[A] b-graph.facebook.com from 192.168.1.5
May 20 17:02:55 dnsmasq[10518]: forwarded b-graph.facebook.com to 1.1.1.1
-----tail of pihole.log------
May 20 17:03:44 dnsmasq[10518]: reply graph.facebook.com is <CNAME>
May 20 17:03:44 dnsmasq[10518]: reply api.facebook.com is <CNAME>
May 20 17:03:44 dnsmasq[10518]: reply star.c10r.facebook.com is 2a03:2880:f058:11:face:b00c:0:2
May 20 17:03:44 dnsmasq[10518]: reply star.c10r.facebook.com is 157.240.221.18
May 20 17:03:52 dnsmasq[10518]: query[AAAA] s.youtube.com from 192.168.1.5
May 20 17:03:52 dnsmasq[10518]: gravity blocked s.youtube.com is ::
May 20 17:03:52 dnsmasq[10518]: query[A] s.youtube.com from 192.168.1.5
May 20 17:03:52 dnsmasq[10518]: gravity blocked s.youtube.com is 0.0.0.0
May 20 17:04:31 dnsmasq[10518]: query[A] us.clickintext.net from 127.0.0.1
May 20 17:04:31 dnsmasq[10518]: gravity blocked us.clickintext.net is 0.0.0.0
May 20 17:04:32 dnsmasq[10518]: query[A] us.clickintext.net from 192.168.1.200
May 20 17:04:32 dnsmasq[10518]: gravity blocked us.clickintext.net is 0.0.0.0
May 20 17:04:53 dnsmasq[10518]: query[AAAA] www.d2v81tfe2x14j0.cloudfront.net from ::1
May 20 17:04:53 dnsmasq[10518]: gravity blocked www.d2v81tfe2x14j0.cloudfront.net is ::
May 20 17:04:54 dnsmasq[10518]: query[AAAA] www.d2v81tfe2x14j0.cloudfront.net from 2a00:23c4:e1c5:8a01:5f86:4412:d6d6:a8ff
May 20 17:04:54 dnsmasq[10518]: gravity blocked www.d2v81tfe2x14j0.cloudfront.net is ::
May 20 17:04:54 dnsmasq[10518]: query[AAAA] www.d2v81tfe2x14j0.cloudfront.net from fe80::322d:fb7d:805f:475d
Why is this happening ?
