with version 5 I was able to disable the blocking for a few minutes using the API.
I was able to use a URL like this: pi.hole/admin/api.php?disable=300&auth=LongApiToken
How may I do the same with version 6? My wife will be very sad, if it cannot be easily deactivated...
I already generated an app password, since there is no API token anymore. But I still cant get it running.
If I try:
https://MyIpAddress/api/disable?auth=LongAppPw=&duration=300
I only get:
{"error":{"key":"not_found","message":"Not found","hint":"/api/disable"},"took":0.00033164024353027344}
So, how may this work with version 6?
Thanks and best regards
Felix
