Disabling Pi-hole and reloading page adds an hour to web interface
When I disable pihole (for no matter what time), and while it's disabled go to a different menu point or even just reload the page, pihole is disabled for another hour (and 3 seconds)
Pihole is disabled for the actual remaining time even when changing the menu or reloading page
It adds an hour (and 3 seconds) upon reloading page
Before reload ->
After reload ->
Pi-hole: v5.6
FTL: v5.11
Web: v5.8
Steps to recreate:
  • Disable pi-hole for a set amount of time
  • Reload page
Bug happened regardless of browser (tested with Brave, Firefox and Edge)
EDIT:
After the original set time runs out, pihole is enabled again. It's just the web-view time which is not correct.
Quite confusing when it happens for the first time as it's unknown if it's still disabled or not.
Tools > Generate Debug Log
I just tried it and could not reproduce the issue. Let's see what your debug shows.
Debug-token:
https://tricorder.pi-hole.net/o3tEeVjj/
    172.16.1.2/24
    172.16.1.3/24
[80] is in use by nginx (https://docs.pi-hole.net/main/prerequisites/#ports)
172.16.1.3:443 nginx (IPv4)
[80] is in use by lighttpd
What kind of setup is this? Are you running nginx in parallel with lighttpd?
Exactly, I have nextcloud and other websites running on nginx on the same device but differnet IPs.
Had problems with that which could be solved here:
Pihole is running on lighttpd as intended
On what port?
Pi-hole / lighttpd -> 172.16.1.2:80
nginx -> 172.16.1.3:80 and :443
they are independent and not intercepting each other
