DHCP with docker-compose on v6
Hi all,
I'm trying to get DHCP working on v6, but a bit confused about the docker DHCP recommendations here: Docker DHCP and Network Modes - Pi-hole documentation
The instructions state to remove all of the ports and add network_mode: host, but now there are a few lines in the docker compose example referring to
# Uncomment the below if using Pi-hole as your DHCP Server
#- "67:67/udp"
and
cap_add:
     # See https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
     # Required if you are using Pi-hole as your DHCP server, else not needed
     - NET_ADMIN
What should the docker compose file look like for v6 to allow for DHCP? Is adding network_mode: host no longer necessary with the new compose file?
Thank you!
I'm using network_mode as I don't run anything else on the ports (53, 67, 80, 443) and v6 is working fine. Both DHCP and DNS.
The relevant part of my compose looks like this.
services:
  pihole:
    network_mode: "host"
#    ports:
      # DNS Ports
#      - "53:53/tcp"
 #     - "53:53/udp"
      # Default HTTP Port
#      - "8081:80/tcp"
      # Default HTTPs Port. FTL will generate a self-signed certificate
#      - "443:443/tcp"
#      - "67:67/udp"
That was my interpretation of the docs, but I am far from a docker expert.
and
cap_add:
     - NET_ADMIN
This I've left in as well.
My understanding is that network_mode: "host" deals with the traffic on all ports, as if the docker container was the host. Primarily this is an easy solution for the broadcast traffic that is DHCP.
You'll want to uncomment all of those bindings.
Exactly. With a bridged docker network, you may have to find a way to forward DHCP requests into the container due to the limitations of subnet broadcast traffic.
Thank you both for your quick replies!
Ended up appending the line in the documentation and the DHCP server is working as intended. The beginning of my docker compose looks like:
services:
  pihole:
    container_name: pihole
    image: pihole/pihole:latest
    ports:
      # DNS Ports
      - "53:53/tcp"
      - "53:53/udp"
      # Default HTTP Port
      - "80:80/tcp"
      - "443:443/tcp"
      - "67:67/udp"
Hopefully getting the ipv6 DHCP will be easy to get running when I flash OpenWRT on my router in the next few weeks
Not in host network mode:
In host network mode, the container's exposed ports are shared with the host directly, so there is no need to publish any ports in host mode.
Docker will ignore them if present.
Declaring port 67 may be necessary in certain other scenarios, e.g. if your router would support relaying DHCP requests to another DHCP server and your Pi-hole container would run in bridge network mode.
OpenWRT is sweet. I think you'll like it.
Thanks @Bucking_Horn. I've always left mine in.
Agree on WRT :smiley:
Yeah so I had to go double check to make sure I'd understood the docs. Like Bucking_Horn said it ignores it.
ubuntu@pihole:~/piholedocker$ docker compose up -d
[+] Running 2/2
 ✔ Container pihole1                                                 Started                                                   4.6s
 ! pihole Published ports are discarded when using host network mode                                                           0.0s
ubuntu@pihole:~/piholedocker$ docker ps
CONTAINER ID   IMAGE                  COMMAND      CREATED          STATUS                            PORTS     NAMES
df69f979fc5f   pihole/pihole:latest   "start.sh"   14 seconds ago   Up 9 seconds (health: starting)             pihole1
It does mean that if I need other services then I'll need to put in a different solution i.e. a DHCP relay server. But that feels too much like my day job!
Nice one, as mentioned already the ports can be removed, commented out as they are ignored. DHCPv6 should be super simple from here, just turn it on in the GUI.
I've set mine up this evening and everything works as expected. Devices are completing the DORA and SARR processes and using v4 and v6 for DNS requests :slight_smile:
I just want to confirm: As I understand it, for the most basic scenarios (i.e. appending network_mode: "host", recomposing, enabling the DHCP server in settings, and disabling DHCP on the router), declaring port 67 will be ignored just like all the other declared ports when in host network mode. Is that correct?
Your router's or any other DHCP server's configuration has zero impact on how Docker treats port assignments.
When using its host network mode, Docker will ignore any published ports.
