DHCP Requested by phone got only 2 minutes, instead of 4h
I use Pi-Hole for a very long time now. Currently on pihole 6 development.
I have about 16 devices served by pihole, but one Samsung phone has a strange dhcp issue. My Leasetime is set to 4 hours. That one phone get a new lease for only 2 minutes.
It request every minute for a renew of the IP adres.
This is the the complete dhcp request from pihole.log and see the lease-time of 2m.
DHCP Request from pihole.log:
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 available DHCP range: 192.168.2.50 -- 192.168.2.109
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 vendor class: android-dhcp-14
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 client provides name: Android-Phone-1
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 DHCPREQUEST(eth0) 192.168.2.64 xy:yx:a2:30:89:23
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 tags: known, eth0
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 DHCPACK(eth0) 192.168.2.64 xy:yx:a2:30:89:23 android-phone-1
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 requested options: 1:netmask, 3:router, 6:dns-server, 15:domain-name,
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 requested options: 26:mtu, 28:broadcast, 51:lease-time, 58:T1,
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 requested options: 59:T2, 43:vendor-encap, 114, 108:ipv6-only
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 next server: 192.168.2.253
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 sent size:  1 option: 53 message-type  5
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 sent size:  4 option: 54 server-identifier  192.168.2.253
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 sent size:  4 option: 51 lease-time  2m
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 sent size:  4 option: 58 T1  53s
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 sent size:  4 option: 59 T2  1m38s
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 sent size:  4 option:  1 netmask  255.255.255.0
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 sent size:  4 option: 28 broadcast  192.168.2.255
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 sent size:  4 option:  6 dns-server  192.168.2.253
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 sent size:  3 option: 15 domain-name  lan
Sep 21 16:00:18 dnsmasq-dhcp[67639]: 1543505873 sent size:  4 option:  3 router  192.168.2.254
See above option 51: lease-time 2m
Is that comming from pihole of or from somthing else?
Pihole leasetime is set to 4 hours.
Leasetime in pihole.toml is set to 4 hours:
ubuntu@odroid:/etc/pihole$ grep 4h pihole.toml
leaseTime = "4h" ### CHANGED, default = ""
The DHCPREQUEST for the phone looks like this in pihole.log:
Part of grep output for DHCPREQUEST in pihole.log:
Sep 21 18:22:31 dnsmasq-dhcp[3894]: 3913809830 DHCPREQUEST(eth0) 192.168.2.64 xy:yx:a2:30:89:23
Sep 21 18:23:31 dnsmasq-dhcp[3894]: 2070630034 DHCPREQUEST(eth0) 192.168.2.64 xy:yx:30:89:23
Sep 21 18:24:32 dnsmasq-dhcp[3894]: 3572629892 DHCPREQUEST(eth0) 192.168.2.64 xy:YX:a2:30:89:23
Sep 21 18:25:33 dnsmasq-dhcp[3894]: 2567706771 DHCPREQUEST(eth0) 192.168.2.64 xy:yx:a2:30:89:23
Sep 21 18:26:34 dnsmasq-dhcp[3894]: 1003353362 DHCPREQUEST(eth0) 192.168.2.64 xy:yx:a2:30:89:23
Sep 21 18:27:35 dnsmasq-dhcp[3894]: 3716788428 DHCPREQUEST(eth0) 192.168.2.64 xy:yx:a2:30:89:23
Sep 21 18:28:35 dnsmasq-dhcp[3894]: 387466275 DHCPREQUEST(eth0) 192.168.2.64 xy:yx:a2:30:89:23
Sep 21 18:29:36 dnsmasq-dhcp[3894]: 3203616886 DHCPREQUEST(eth0) 192.168.2.64 xy:yx:a2:30:89:23
Sep 21 18:30:37 dnsmasq-dhcp[3894]: 3517785719 DHCPREQUEST(eth0) 192.168.2.64 xy:yx:a2:30:89:23
Sep 21 18:31:38 dnsmasq-dhcp[3894]: 2026294367 DHCPREQUEST(eth0) 192.168.2.64 xy:yx:a2:30:89:23
Sep 21 18:32:39 dnsmasq-dhcp[3894]: 3077729820 DHCPREQUEST(eth0) 192.168.2.64 xy:yx:a2:30:89:23
Why every minute a new DHCPREQUEST from only one Samsung android phone!
Another but older Samsung phone has not this problem. Both phones are running Android 14.
Pihole version:
ubuntu@odroid:/var/log/pihole$ pihole -v
Core
    Version is v5.18.3-479-ge3dc067 (Latest: null)
    Branch is development
    Hash is e3dc0670 (Latest: e3dc0670)
Web
    Version is v5.21-951-g32f89861 (Latest: null)
    Hash is 32f89861 (Latest: 32f89861)
FTL
    Version is vDev-23e614c (Latest: null)
    Hash is 23e614cc (Latest: 23e614cc)
The pihole-server is used for dhcp and dns and is running ubuntu 2404 on a odroid-c4 with all updates.
I can upload a debug log to tricorder if requested.
I want to know if this is a pihole problem or bug, or is it a phone issue.
Gerrit.
Run from your Pi-hole host machine, please share the output of:
sudo ss -tulpn sport = 53 or sport = 67
This is the requested output:
ubuntu@odroid:~$ sudo ss -tulpn sport = 53 or sport = 67
Netid   State    Recv-Q   Send-Q     Local Address:Port     Peer Address:Port   Process
udp     UNCONN   0        0                0.0.0.0:53            0.0.0.0:*       users:(("pihole-FTL",pid=3894,fd=18))
udp     UNCONN   0        0                0.0.0.0:67            0.0.0.0:*       users:(("pihole-FTL",pid=3894,fd=16))
udp     UNCONN   0        0                   [::]:53               [::]:*       users:(("pihole-FTL",pid=3894,fd=20))
tcp     LISTEN   0        32               0.0.0.0:53            0.0.0.0:*       users:(("pihole-FTL",pid=3894,fd=19))
tcp     LISTEN   0        32                  [::]:53               [::]:*       users:(("pihole-FTL",pid=3894,fd=21))
This shows that currently only pihole-FTL (Pi-hole's tailored dnsmasq) is listening on those ports.
Note how "pihole-FTL", pid=3894 matches dnsmasq-dhcp[3894]from your later DHCPREQUEST output, but not the earlier one.
As pihole-FTL would acquire a new pid any time it restarts, this may still have been Pi-hole, e.g. if you'd have disabled and reenabled Pi-hole's DHCP server or rebooted your machine in between those logs.
If not, then there could have been another dnsmasq instance running at that time, which wouldn't be currently active anymore (or it would have registered in your ss output).
Are you running other software on the same machine besides Pi-hole?
Also, please upload a debug log and post just the token URL that is generated after the log is uploaded by running the following command from the Pi-hole host terminal:
Yes I did a disable/enable DHCP on the odroid server. This was because I wanted to test if the issue was present on another (backup) pihole server. And yes the issue was al there present.
This is the current pid info:
ubuntu@odroid:~$ ps -ef | grep dnsmasq | grep -v grep
ubuntu@odroid:~$ ps -ef | grep FTL | grep -v grep
pihole 3894 1 0 Sep21 ? 00:08:37 /usr/bin/pihole-FTL -f
ubuntu@odroid:~$
Thus no dnsmasq running at the moment.
Your debug token is: https://tricorder.pi-hole.net/WLoEYKnu/
Your debug log shows a malformed dhcp client lease configuration:
-rw-r--r-- 1 pihole pihole 8.0K Sep 21 18:01 /etc/pihole/dnsmasq.conf
 dhcp-host=xx:xx:xx:xx:xx:23,192,168,2,64,a25-van-marja
Note the commas instead of points in what seems to be an IP address, turning the numbers into options, where 2 is your 2minutes.
Likely, that should read as follows instead:
 dhcp-host=xx:xx:xx:xx:xx:23,192.168.2.64,a25-van-marja
It looks it is solved after I did correct it via the webgui.
Thanks for your support.
Post-mortem
The dnsmasq syntax for this option is
dhcp-host=[<hwaddr>][,id:<client_id>|*][,set:<tag>][,tag:<tag>][,<ipaddr>][,<hostname>][,<lease_time>][,ignore]
Interestingly, dnsmasq parses all your 192,168,2,64 as <lease_time> as they do not match any other category. It then decides to use the last one (64 seconds) as the intended one.
So, why have you seen 120 and not 64 seconds? Well, there is now some additional (undocumented!) code in dnsmasq which bends these 64 seconds to those 120 seconds:
