DHCP problem with static ip
Hi, I have pihole installed on my proxmox in CT container. I'm facing issue that my static config is not always taken. For example i had new esp8266 device. I installed WLED on it and before connecting to my wifi i added static config for mac address. I see that connecting to wifi takes lot of time and in result ip from DHCP range instead of static config.
Aug 17 10:57:50 dnsmasq-dhcp[164]: DHCPDISCOVER(eth0) cc:50:e3:0b:9b:18
Aug 17 10:57:50 dnsmasq-dhcp[164]: DHCPOFFER(eth0) 192.168.1.184 cc:50:e3:0b:9b:18
Aug 17 10:57:50 dnsmasq-dhcp[164]: DHCPREQUEST(eth0) 192.168.1.184 cc:50:e3:0b:9b:18
Aug 17 10:57:50 dnsmasq-dhcp[164]: DHCPACK(eth0) 192.168.1.184 cc:50:e3:0b:9b:18 wled-WLED
Config:
dhcp-authoritative
dhcp-range=192.168.1.150,192.168.1.220,10h
dhcp-option=option:router,192.168.1.1
dhcp-leasefile=/etc/pihole/dhcp.leases
#quiet-dhcp
domain=local
dhcp-host=CC:50:E3:0B:9B:18,192.168.1.21,agatka-lampka2
Do you know what might be an issue? On CC:50:E3:0B:9B:18 dhcp is on. Should i change it to static config? I thought that with static config dhcp server should offer static ip.
PS: other DHCP servers, for example on router, are disabled.
Update: after lease removal and pihole restart proper IP were assigned
Aug 17 11:29:08 dnsmasq-dhcp[165]: DHCPDISCOVER(eth0) cc:50:e3:0b:9b:18
Aug 17 11:29:08 dnsmasq-dhcp[165]: DHCPOFFER(eth0) 192.168.1.21 cc:50:e3:0b:9b:18
Aug 17 11:29:08 dnsmasq-dhcp[165]: DHCPREQUEST(eth0) 192.168.1.21 cc:50:e3:0b:9b:18
Aug 17 11:29:08 dnsmasq-dhcp[165]: DHCPACK(eth0) 192.168.1.21 cc:50:e3:0b:9b:18 agatka-lampka2
Do i need to restart pihole on static ip config change?
The issue seems that Pi-hole's DHCP server does not hand out the dhcp-host defined 192.168.1.21, but an IPv4 address from its dynamic range.
One notable difference here is that the MAC address from the logs is all lower case, while the dhcp-host definition is all upper case.
Despite expecting that to be case-insensitive:
Did you try to change that dhcp-host to lower case yet?
I'm managing pihole via GUI. I did a test and put manually static ip with mac address with lower case. It was converted to upper case. So i think that it is not case sensitive. Interesting thing is that after pihole restart ip were properly assigned.
