Hi All,
I was using the master for a while and had the DHCP option 252 set which worked well.
I have since moved to the FTLDNS version and can't seem to get it to work.
Any help? Which location should I be placing it in?
Hi All,
What do you mean by "DHCP option 252"?
How are you setting the option, can you paste a copy of the configuration and the name of the file you are setting it with?
That doesnt seem to be a valid default DHCP option:
pi@noads:~ $ dnsmasq --help dhcp
Known DHCP options:
1 netmask
2 time-offset
3 router
6 dns-server
7 log-server
9 lpr-server
13 boot-file-size
15 domain-name
16 swap-server
17 root-path
18 extension-path
19 ip-forward-enable
20 non-local-source-routing
21 policy-filter
22 max-datagram-reassembly
23 default-ttl
26 mtu
27 all-subnets-local
31 router-discovery
32 router-solicitation
33 static-route
34 trailer-encapsulation
35 arp-timeout
36 ethernet-encap
37 tcp-ttl
38 tcp-keepalive
40 nis-domain
41 nis-server
42 ntp-server
44 netbios-ns
45 netbios-dd
46 netbios-nodetype
47 netbios-scope
48 x-windows-fs
49 x-windows-dm
58 T1
59 T2
60 vendor-class
64 nis+-domain
65 nis+-server
66 tftp-server
67 bootfile-name
68 mobile-ip-home
69 smtp-server
70 pop3-server
71 nntp-server
74 irc-server
77 user-class
93 client-arch
94 client-interface-id
97 client-machine-id
119 domain-search
120 sip-server
121 classless-static-route
125 vendor-id-encap
255 server-ip-address
I'm trying to setup an auto discovery pac file. Broadcast by DHCP.
Aha this one ?
dhcp-option=252,http://your.server.here/wpad.dat
You can place it in a new dnsmasq config file like for example:
/etc/dnsmasq.d/13-wpad.conf
EDIT: oops, not sure bout above bit with the new FTLDNS ![]()
I have no experience with WPAD but if install "nmap" on a client, below one might come in handy:
sudo nmap -sU -p67 --script dhcp-discover <PIHOLE_IP_ADDRESS>
