DHCP no give IPs in docker
When I set active DHCP in Docker container, clients not receive IP.
I think I probed everything.
This is compose...
  pihole:
    restart: unless-stopped
    container_name: mipihole
    image: pihole/pihole
    environment:
      - TZ=Europe/Madrid
      - WEBPASSWORD=xxxxx
      - FTLCONF_LOCAL_IPV4=192.168.5.10
      - DNSMASQ_LISTENING=all
      - INTERFACE=br0
      - PIHOLE_DNS_=127.0.0.1#1531
      - DHCP_ACTIVE=true # enable DHCP Server. Static DHCP leases can be configured with a custom /etc/dnsmasq.d/04-pihole-static-dhcp.conf
      - DHCP_START=192.168.5.100 # start of the range of IP addresses to hand out by the DHCP Server (mandatory if DHCP Server is enabled)
      - DHCP_END=192.168.5.250 # end of the range of IP addresses to hand out by the DHCP Server (mandatory if DHCP Server is enabled)
      - DHCP_ROUTER=192.168.5.10 # router (gateway) IP addresses sent by the DHCP server (mandatory if DHCP Server is enabled)
      - DHCP_LEASETIME=1 # hours DHCP lease time
      - DHCP_IPv6=false # enable DHCP server ipv6 support
      - PIHOLE_DOMAIN=mydomain # domain name sent by DHCP Server
      - QUERY_LOGGING=true # Enable query logging or not
      - PIHOLE_DOCKER_TAG=mipihole
      - WEBLOGS_STDOUT=1
    volumes:
      - /docker/mipihole/etc:/etc/pihole
      - /docker/mipihole/dnsmasq:/etc/dnsmasq.d
      - /docker/mipihole/milighttpd.conf:/etc/lighttpd/conf-enabled/milighttpd.conf
      - /var/log/docker-mipihole:/var/log/pihole
    network_mode: "host"
    cap_add:
      - NET_ADMIN
This is the list of networks...
~# ip ad | grep "inet "
    inet 192.168.0.10/24 brd 192.168.0.255 scope global eth0
    inet 192.168.5.10/24 brd 192.168.5.255 scope global br0
    inet 172.20.0.1/24 brd 172.20.0.255 scope global midockerbr
    inet 172.20.1.1/24 brd 172.20.1.255 scope global midockerbrpriv
    inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
Ports are opened and working (in Host, because is in 'network_mode="host"')...
~# ss -putanl | grep pihole
udp   UNCONN 0      0            0.0.0.0:53         0.0.0.0:*    users:(("pihole-FTL",pid=121401,fd=6))
udp   UNCONN 0      0            0.0.0.0:67         0.0.0.0:*    users:(("pihole-FTL",pid=121401,fd=4))
udp   UNCONN 0      0               [::]:53            [::]:*    users:(("pihole-FTL",pid=121401,fd=8))
tcp   LISTEN 0      5          127.0.0.1:4711       0.0.0.0:*    users:(("pihole-FTL",pid=121401,fd=12))
tcp   LISTEN 0      32           0.0.0.0:53         0.0.0.0:*    users:(("pihole-FTL",pid=121401,fd=7))
tcp   LISTEN 0      5              [::1]:4711          [::]:*    users:(("pihole-FTL",pid=121401,fd=17))
tcp   LISTEN 0      32              [::]:53            [::]:*    users:(("pihole-FTL",pid=121401,fd=9))
~# nc -v -n -q 2 -u 127.0.0.1 67
(UNKNOWN) [127.0.0.1] 67 (bootps) open
^C
~# nc -v -n -u 192.168.5.10 67
(UNKNOWN) [192.168.5.10] 67 (bootps) open
But the log activity of DHCP is only...
~# grep -i dhcp /var/log/docker-mipihole/pihole.log
Jan 29 23:25:43 dnsmasq[298]: compile time options: IPv6 GNU-getopt no-DBus no-UBus no-i18n IDN DHCP DHCPv6 Lua TFTP no-conntrack ipset no-nftset auth cryptohash DNSSEC loop-detect inotify dumpfile
Jan 29 23:25:43 dnsmasq-dhcp[298]: DHCP, IP range 192.168.5.100 -- 192.168.5.250, lease time 1h
Not appears any activity of clients, but I'm probing unsuccessfully.
I think the problem is pihole, because before I had an keadhcp container working without problem, in 'network_mode="host"' too, and all clients received their IPs.
Not work. It seems to freeze and does not finish.
I've discovered that there are any activity and it's of MAC of my bridge iface (br0), that is not a physical MAC. This physical bridge is formed by some ethernet connectors from my physical hardware:
Jan 30 12:29:14 dnsmasq-dhcp[302]: DHCPDISCOVER(br0) 02:46:7d:2f:6f:54
Jan 30 12:29:14 dnsmasq-dhcp[302]: DHCPOFFER(br0) 192.168.5.138 02:46:7d:2f:6f:54
I don't know if this item is related.
