are you sure the client devices are using pi hole as the only dns
if your on Windows please post the output of ipconfig /all
On a Mac, here's my ifconfig output:
(For reference, Pi-Hole is on 192.168.178.25 and router on 178.1
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
inet 127.0.0.1 netmask 0xff000000
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
XHC20: flags=0<> mtu 0
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 60:f8:1d:b2:5f:0a
inet6 fe80::18e0:d729:c45f:c861%en0 prefixlen 64 secured scopeid 0x5
inet6 2001:1c02:2b0b:4800:1cfe:b3e0:7ebe:110 prefixlen 64 autoconf secured
inet6 2001:1c02:2b0b:4800:d9d8:be20:d75:15e prefixlen 64 autoconf temporary
inet 192.168.178.206 netmask 0xffffff00 broadcast 192.168.178.255
media: autoselect
status: active
p2p0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 2304
ether 02:f8:1d:b2:5f:0a
media: autoselect
status: inactive
awdl0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1484
ether 7a:3b:da:3e:84:41
inet6 fe80::783b:daff:fe3e:8441%awdl0 prefixlen 64 scopeid 0x7
media: autoselect
status: active
en1: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
options=60<TSO4,TSO6>
ether 72:00:07:66:9b:40
media: autoselect <full-duplex>
status: inactive
en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 72:00:07:66:9b:41
status: inactive
bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=63<RXCSUM,TXCSUM,TSO4,TSO6>
Configuration:
id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
ipfilter disabled flags 0x2
member: en1 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 8 priority 0 path cost 0
member: en2 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 9 priority 0 path cost 0
media: <unknown type>
status: inactive
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
inet6 fe80::8728:658b:5c16:cb03%utun0 prefixlen 64 scopeid 0xb
Your debug log shows no DNS traffic coming to Pi-Hole from your network. After you made the DHCP change, did you reboot the router and renew the DHCP lease on all clients?
I believe I did before, but to make sure I've just rebooted the router and have renewed DHCP leases on the devices that I'm able to. Still no luck (although looking at the logs, it looks like there may be some DNS activity).
> [2020-02-07 08:16:15.019 1443] Imported 10 queries from the long-term database
> [2020-02-07 08:16:15.019 1443] -> Total DNS queries: 10
> [2020-02-07 08:16:15.019 1443] -> Cached DNS queries: 2
> [2020-02-07 08:16:15.019 1443] -> Forwarded DNS queries: 8
> [2020-02-07 08:16:15.019 1443] -> Exactly blocked DNS queries: 0
> [2020-02-07 08:16:15.019 1443] -> Unknown DNS queries: 0
> [2020-02-07 08:16:15.019 1443] -> Unique domains: 4
> [2020-02-07 08:16:15.019 1443] -> Unique clients: 1
> [2020-02-07 08:16:15.019 1443] -> Known forward destinations: 1
New debug token is: https://tricorder.pi-hole.net/hva46a3zrv
