Hello all,
is it possible to install Pi-hole (raspbian) on a container having a custom ip for http and also operate as a dhcp server? I know that in order for DHCP to work pihole should run in network_mode, however when you run it on network_mode how can you use a different ip for webui? Here is the composer file that i use:
version: "3"
services:
pihole:
container_name: pihole
image: pihole/pihole:latest
network_mode: "host"
ports:
- "53:53/tcp"
- "53:53/udp"
- "67:67/udp"
- "8081:80/tcp"
environment:
TZ: 'Europe/Athens'
WEBPASSWORD: '123'
volumes:
- './etc-pihole:/etc/pihole'
cap_add:
- NET_ADMIN
restart: unless-stopped
BR
Manolis
