Pi-hole acts as DHCP server and starts assigning IP's to devices which provides a working internet connection while my previous routers' DHCP service is disabled.
This works but anywhere from 5-15 minutes after I start the DHCP service on the Pi I lose connection to the internet on all of the devices on my LAN that are using the Pi as the DHCP server. Also, the status section of the WebUI says "DNS service: not running FTL: offline" and when I run pihole -r to repair, it gets fixed but again breaks when i go to re-enable the DHCP on the pi.
**I feel the need to say that when I do have the pi handling DHCP, my router is not, and vice versa.
Edit:
Not sure if it helps but my router is an NVG589 which doesn't support changing the DNS put does allow a "passthrough" workaround of some sorts.
(if anyone has a router that works really well with their Pi-hole please let me know what kind because I'm looking into upgrading mine and am open to suggestions.)
Here's the token for the Dev's:
https://tricorder.pi-hole.net/28mvccg89h
And the Debug output for anyone else:
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2019-06-12:05:20:35 debug log has been initialized.
[i] Core: v4.3 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3-0-g1d43c0a
[i] Web: v4.3 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3-0-g44aff727
[✓] FTL: v4.3.1
[i] 1.4.45
[i] 7.0.30
[✓] Raspbian GNU/Linux 9 (stretch)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[✓] armv7l
192.168.1.175/24 matches the IP found in /etc/pihole/setupVars.conf
fe80::c893:ab9f:75cc:a6bd does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 192.168.1.254
* Pinging 192.168.1.254...
[✓] Gateway responded.
[i] Default IPv6 gateway: fe80::8661:a0ff:fecf:b9f0
* Pinging fe80::8661:a0ff:fecf:b9f0...
*:22 sshd (IPv4)
*:22 sshd (IPv6)
*:5938 teamviewer (IPv6)
*:5938 teamviewer (IPv4)
127.0.0.1:5940 teamviewer (IPv4)
[*:80] is in use by lighttpd
[✗] Failed to resolve ad.clovenetwork.com via localhost (127.0.0.1)
[✗] Failed to resolve ad.clovenetwork.com via Pi-hole (192.168.1.175)
[✓] doubleclick.com is 172.217.9.78 via a remote, public DNS server (8.8.8.8)
[✗] Failed to resolve webhostforseo.com via localhost (::1)
[✗] Failed to resolve webhostforseo.com via Pi-hole (2600:1702:28c0:b2c0:b558:416d:a36c:92c8)
[✗] Failed to resolve doubleclick.com via a remote, public DNS server (2001:4860:4860::8888)
[✓] lighttpd daemon is active
TEMPERATUREUNIT=F
ADMIN_EMAIL=nbiliti@gmail.com
WEBUIBOXEDLAYOUT=boxed
HOSTRECORD=
BLOCKING_ENABLED=true
DNSMASQ_LISTENING=single
PIHOLE_DNS_3=2001:4860:4860:0:0:0:0:8888
PIHOLE_DNS_4=2001:4860:4860:0:0:0:0:8844
DNS_FQDN_REQUIRED=true
DNS_BOGUS_PRIV=true
DNSSEC=false
CONDITIONAL_FORWARDING=true
CONDITIONAL_FORWARDING_IP=192.168.1.254
CONDITIONAL_FORWARDING_DOMAIN=attlocal.net
CONDITIONAL_FORWARDING_REVERSE=1.168.192.in-addr.arpa
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.1.175/24
IPV6_ADDRESS=2600:1702:28c0:b2c0:b558:416d:a36c:92c8
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
DHCP_START=192.168.1.1
DHCP_END=192.168.1.253
DHCP_ROUTER=192.168.1.254
DHCP_LEASETIME=.25
PIHOLE_DOMAIN=Pi-Hole
DHCP_IPv6=false
DHCP_rapid_commit=true
DHCP_ACTIVE=false
[✓] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements.
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 2655483 Jun 12 04:32 /etc/pihole/gravity.list
0.0.0.0
0.nextyourcontent.com
0.r.msn.com
0.start.bz
zzz.clickbank.net
zzzezeroe.fr
zzzpooeaz-france.com
zzzrtrcm2.com
-rw-r--r-- 1 root root 381 Jun 12 04:26 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 0 Jun 12 03:00 /etc/pihole/blacklist.txt
-rw-r--r-- 1 root root 140 Jun 12 04:32 /etc/pihole/local.list
192.168.1.175 Pi-hole
2600:1702:28c0:b2c0:b558:416d:a36c:92c8 Pi-hole
192.168.1.175 pi.hole
2600:1702:28c0:b2c0:b558:416d:a36c:92c8 pi.hole
-rw-r--r-- 1 root root 234 Jun 12 04:32 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 747 May 13 21:18 /etc/pihole/whitelist.txt
raw.githubusercontent.com
us1-zcash.flypool.org
eth-us-east1.nanopool.org
eth-us-west1.nanopool.org
eth-eu1.nanopool.org
eth-eu2.nanopool.org
eth-asia1.nanopool.org
zcash.flypool.org
api-zcash.flypool.org
spclient.wg.spotify.com
api.ledgerwallet.com
rover.ebay.com
graph.accountkit.com
t.appsflyer.com
beta.spotify.map.fastly.net
continuum.dds.microsoft.com
etc.2miners.com
2miners.com
etc.ethermine.org
us1-etc.ethermine.org
m.stripe.network
api-etc.ethermine.org
medium.freecodecamp.org
us1.ethpool.org
us1.ethermine.org
biosagentplus.com
btgpool.pro
pool.gold
europe.equihash-hub.miningpoolhub.com
slushpool.com
www.multiminerapp.com
mint.bitminter.com
bitminer.io
bitminter.com
ethermine.org
api.ethermine.org
eth.nanopool.org
eth.2miners.com
-rw-r--r-- 1 root root 1690 Jun 12 04:53 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=8.8.8.8
server=8.8.4.4
server=2001:4860:4860:0:0:0:0:8888
server=2001:4860:4860:0:0:0:0:8844
domain-needed
bogus-priv
interface=eth0
server=/attlocal.net/192.168.1.254
server=/1.168.192.in-addr.arpa/192.168.1.254
-rw-r--r-- 1 root root 3102 Jun 12 04:32 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1704 Jun 12 04:32 /etc/cron.d/pihole
39 4 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
34 17 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 14478 Jun 12 05:20 /var/log/lighttpd/error.log
2019-06-09 06:25:02: (server.c.1534) logfiles cycled UID = 0 PID = 7584
2019-06-11 15:48:40: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Uninitialized string offset: 0 in /var/www/html/admin/scripts/pi-hole/php/queryads.php on line 26
2019-06-11 15:48:40: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10
2019-06-11 15:49:10: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: file(http://127.0.0.1/admin/scripts/pi-hole/php/queryads.php?domain=unknownb827eb51c411.attlocal.net&bp): failed to open stream: HTTP request failed! in /var/www/html/pihole/index.php on line 137
2019-06-11 15:49:10: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_filter() expects parameter 1 to be array, string given in /var/www/html/pihole/index.php on line 138
2019-06-11 15:49:10: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_values() expects parameter 1 to be array, null given in /var/www/html/pihole/index.php on line 138
2019-06-11 15:49:15: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Undefined index: HTTP_HOST in /var/www/html/pihole/index.php on line 10
2019-06-11 15:49:15: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: file(http://127.0.0.1/admin/scripts/pi-hole/php/queryads.php?domain=&bp): failed to open stream: HTTP request failed! in /var/www/html/pihole/index.php on line 137
2019-06-11 15:49:15: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_filter() expects parameter 1 to be array, string given in /var/www/html/pihole/index.php on line 138
2019-06-11 15:49:15: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_values() expects parameter 1 to be array, null given in /var/www/html/pihole/index.php on line 138
2019-06-11 15:49:16: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: file(http://127.0.0.1/admin/scripts/pi-hole/php/queryads.php?domain=unknownb827eb51c411.attlocal.net&bp): failed to open stream: HTTP request failed! in /var/www/html/pihole/index.php on line 137
2019-06-11 15:49:16: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_filter() expects parameter 1 to be array, string given in /var/www/html/pihole/index.php on line 138
2019-06-11 15:49:16: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_values() expects parameter 1 to be array, null given in /var/www/html/pihole/index.php on line 138
2019-06-11 15:49:16: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Notice: Uninitialized string offset: 0 in /var/www/html/admin/scripts/pi-hole/php/queryads.php on line 26
2019-06-11 15:49:21: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: file(http://127.0.0.1/admin/scripts/pi-hole/php/queryads.php?domain=unknownb827eb51c411.attlocal.net&bp): failed to open stream: HTTP request failed! in /var/www/html/pihole/index.php on line 137
2019-06-11 15:49:21: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Warning: array_filter() expects parameter 1 to be array, string given in /var/www/html/pihole/index.php on line 138
-rw-r--r-- 1 pihole pihole 45856 Jun 12 04:46 /var/log/pihole-FTL.log
[2019-06-12 01:56:56.687 1135] Using log file /var/log/pihole-FTL.log
[2019-06-12 01:56:56.687 1135] ########## FTL started! ##########
[2019-06-12 01:56:56.688 1135] FTL branch: master
[2019-06-12 01:56:56.688 1135] FTL version: v4.3.1
[2019-06-12 01:56:56.688 1135] FTL commit: b60d63f
[2019-06-12 01:56:56.688 1135] FTL date: 2019-05-25 21:37:26 +0200
[2019-06-12 01:56:56.688 1135] FTL user: pihole
[2019-06-12 01:56:56.688 1135] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2019-06-12 01:56:56.688 1135] SOCKET_LISTENING: only local
[2019-06-12 01:56:56.688 1135] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2019-06-12 01:56:56.688 1135] MAXDBDAYS: max age for stored queries is 365 days
[2019-06-12 01:56:56.688 1135] RESOLVE_IPV6: Resolve IPv6 addresses
[2019-06-12 01:56:56.688 1135] RESOLVE_IPV4: Resolve IPv4 addresses
[2019-06-12 01:56:56.688 1135] DBINTERVAL: saving to DB file every minute
[2019-06-12 01:56:56.688 1135] DBFILE: Using /etc/pihole/pihole-FTL.db
[2019-06-12 01:56:56.688 1135] MAXLOGAGE: Importing up to 24.0 hours of log data
[2019-06-12 01:56:56.688 1135] PRIVACYLEVEL: Set to 0
[2019-06-12 01:56:56.688 1135] IGNORE_LOCALHOST: Show queries from localhost
[2019-06-12 01:56:56.688 1135] BLOCKINGMODE: Null IPs for blocked domains
[2019-06-12 01:56:56.688 1135] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2019-06-12 01:56:56.688 1135] DBIMPORT: Importing history from database
[2019-06-12 01:56:56.689 1135] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-06-12 01:56:56.689 1135] PORTFILE: Using /var/run/pihole-FTL.port
[2019-06-12 01:56:56.689 1135] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-06-12 01:56:56.689 1135] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2019-06-12 01:56:56.689 1135] BLACKLISTFILE: Using /etc/pihole/black.list
[2019-06-12 01:56:56.689 1135] GRAVITYFILE: Using /etc/pihole/gravity.list
[2019-06-12 01:56:56.689 1135] REGEXLISTFILE: Using /etc/pihole/regex.list
[2019-06-12 01:56:56.689 1135] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2019-06-12 01:56:56.689 1135] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2019-06-12 01:56:56.689 1135] MACVENDORDB: Using /etc/pihole/macvendor.db
[2019-06-12 01:56:56.689 1135] PARSE_ARP_CACHE: Active
[2019-06-12 01:56:56.689 1135] Finished config file parsing
[2019-06-12 01:56:56.727 1135] Database version is 3
[2019-06-12 01:56:56.727 1135] Database successfully initialized
[2019-06-12 04:46:15.263 26914] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2019-06-12 04:46:15.263 26914] DBIMPORT: Importing history from database
[2019-06-12 04:46:15.263 26914] PIDFILE: Using /var/run/pihole-FTL.pid
[2019-06-12 04:46:15.263 26914] PORTFILE: Using /var/run/pihole-FTL.port
[2019-06-12 04:46:15.263 26914] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2019-06-12 04:46:15.263 26914] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2019-06-12 04:46:15.263 26914] BLACKLISTFILE: Using /etc/pihole/black.list
[2019-06-12 04:46:15.263 26914] GRAVITYFILE: Using /etc/pihole/gravity.list
[2019-06-12 04:46:15.263 26914] REGEXLISTFILE: Using /etc/pihole/regex.list
[2019-06-12 04:46:15.263 26914] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2019-06-12 04:46:15.264 26914] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2019-06-12 04:46:15.264 26914] MACVENDORDB: Using /etc/pihole/macvendor.db
[2019-06-12 04:46:15.264 26914] PARSE_ARP_CACHE: Active
[2019-06-12 04:46:15.264 26914] Finished config file parsing
[2019-06-12 04:46:15.265 26914] Database version is 3
[2019-06-12 04:46:15.265 26914] Database successfully initialized
[2019-06-12 04:46:15.266 26914] New forward server: 2001:4860:4860::8844 (0/512)
[2019-06-12 04:46:15.266 26914] New forward server: 192.168.1.254 (1/512)
[2019-06-12 04:46:15.266 26914] New forward server: 8.8.4.4 (2/512)
[2019-06-12 04:46:15.266 26914] New forward server: 8.8.8.8 (3/512)
[2019-06-12 04:46:15.267 26914] New forward server: 2001:4860:4860::8888 (4/512)
[2019-06-12 04:46:15.268 26914] Resizing "/FTL-strings" from 4096 to 8192
[2019-06-12 04:46:15.277 26914] Resizing "/FTL-strings" from 8192 to 12288
[2019-06-12 04:46:15.289 26914] Resizing "/FTL-strings" from 12288 to 16384
[2019-06-12 04:46:15.301 26914] Resizing "/FTL-strings" from 16384 to 20480
[2019-06-12 04:46:15.316 26914] Imported 4078 queries from the long-term database
[2019-06-12 04:46:15.317 26914] -> Total DNS queries: 4078
[2019-06-12 04:46:15.317 26914] -> Cached DNS queries: 896
[2019-06-12 04:46:15.317 26914] -> Forwarded DNS queries: 2287
[2019-06-12 04:46:15.317 26914] -> Exactly blocked DNS queries: 895
[2019-06-12 04:46:15.317 26914] -> Unknown DNS queries: 0
[2019-06-12 04:46:15.317 26914] -> Unique domains: 717
[2019-06-12 04:46:15.317 26914] -> Unique clients: 30
[2019-06-12 04:46:15.317 26914] -> Known forward destinations: 5
[2019-06-12 04:46:15.317 26914] Successfully accessed setupVars.conf
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 pihole pihole 323584 Jun 12 04:46 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 108 Jun 12 04:46 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 65536 Jun 12 04:46 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 12288 Jun 12 04:46 /dev/shm/FTL-forwarded
-rw------- 1 pihole pihole 28 Jun 12 04:46 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 53248 Jun 12 04:46 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 196608 Jun 12 04:46 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 12 Jun 12 04:46 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 20480 Jun 12 04:46 /dev/shm/FTL-strings
*** [ DIAGNOSING ]: Locale
LANG=
-rw-r--r-- 1 pihole pihole 1447750 Jun 12 04:46 /var/log/pihole.log
-----head of pihole.log------
Jun 12 01:56:56 dnsmasq[1138]: started, version pi-hole-2.80 cachesize 10000
Jun 12 01:56:56 dnsmasq[1138]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth DNSSEC loop-detect inotify dumpfile
Jun 12 01:56:56 dnsmasq[1138]: using nameserver 192.168.1.254#53 for domain 1.168.192.in-addr.arpa
Jun 12 01:56:56 dnsmasq[1138]: using nameserver 192.168.1.254#53 for domain attlocal.net
Jun 12 01:56:56 dnsmasq[1138]: using nameserver 2001:4860:4860::8844#53
Jun 12 01:56:56 dnsmasq[1138]: using nameserver 2001:4860:4860::8888#53
Jun 12 01:56:56 dnsmasq[1138]: using nameserver 8.8.4.4#53
Jun 12 01:56:56 dnsmasq[1138]: using nameserver 8.8.8.8#53
Jun 12 01:56:56 dnsmasq[1138]: read /etc/hosts - 5 addresses
Jun 12 01:56:56 dnsmasq[1138]: read /etc/pihole/local.list - 4 addresses
Jun 12 01:56:56 dnsmasq[1138]: read /etc/pihole/black.list - 0 addresses
Jun 12 01:57:22 dnsmasq[1138]: read /etc/pihole/gravity.list - 3748552 addresses
Jun 12 01:57:22 dnsmasq[1138]: query[A] ping3.teamviewer.com from 127.0.0.1
Jun 12 01:57:22 dnsmasq[1138]: forwarded ping3.teamviewer.com to 2001:4860:4860::8844
Jun 12 01:57:22 dnsmasq[1138]: forwarded ping3.teamviewer.com to 2001:4860:4860::8888
Jun 12 01:57:22 dnsmasq[1138]: forwarded ping3.teamviewer.com to 8.8.4.4
Jun 12 01:57:22 dnsmasq[1138]: forwarded ping3.teamviewer.com to 8.8.8.8
Jun 12 01:57:22 dnsmasq[1138]: query[A] epdg.epc.att.net from 2600:1702:28c0:b2c0:5824:c508:142:ba28
Jun 12 01:57:22 dnsmasq[1138]: forwarded epdg.epc.att.net to 2001:4860:4860::8844
Jun 12 01:57:22 dnsmasq[1138]: forwarded epdg.epc.att.net to 2001:4860:4860::8888
[✓] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
[✓] Your debug token is: https://tricorder.pi-hole.net/28mvccg89h
* Provide the token above to the Pi-hole team for assistance at
* https://discourse.pi-hole.net
* Your log will self-destruct on our server after 48 hours.
* A local copy of the debug log can be found at: /var/log/pihole_debug.log
