Device specific whitelist, block anything else
With the group management, I can setup lists for specific devices.
Can I setup a device group which only can connect to defined records in the whitelist?
Anything else should be blocked within the device group.
Sure. Create a new group, assign the desired clients to this group only, add a all blocking RegEx (.*) and add whitelisted entries as desired.
ok, regex should be just (.*)?
I think it works, thanks.
Without the brackets, although I think it would still happen to work with them. So just
