Deleting a Group is not possible - FTL v6.0.4
Hi Pi-hole Team
I updated my Installation to Pi-hole v6, but it failed so I had to do a reinstall. After the reinstall I imported my backup through the Pi-hole Webinterface. Everything works like before, except deleting a group. Yesterday I wanted to delete a group and get the following message in return.
Could not remove entries from table
FOREIGN KEY constraint failed
I think the reinstall with a backup messed something up.
Could you maybe help me out what causes this problem?
Thanks a lot in advance :slight_smile:
https://tricorder.pi-hole.net/BR8ER6XX/
I have the same .. some detail i find:
I can delete groups created with v6 but cant delete groups which was created with v5 before the update.
Push
Push…
Still have this problem, maybe someone can help.
Please upload a new debug log and post the new token URL. Your previous log expired before we got to it.
Sure. New token is: https://tricorder.pi-hole.net/1akff5S2/
This message means the database can't delete the group because there are lists and domains using it.
This is different from the Pi-hole v5 behavior, where you can remove a group even if it is used.
I think this can be considered an issue and I can replicate it.
Bugfix:
I agree with the new code (just removing the assignment, without actually deleting the "child" items) is the best approach.
We are currently working on the fix but it is unclear what should actually happen. What is your opinion how this feature should work?
  • It should not be possible to delete groups which still have associated domains or clients
  • It should be possible to delete groups which still have associated domains or clients. The previously associated domains and clients should remain, but unassigned from the just deleted group
  • It should be possible to delete groups which still have associated domains or clients. Associated domains and clients should be removed as well (cascading deletion down)
0 voters
