Delete queries error
Hello,
Pi-hole v5.9
FTL v5.14
Web Interface v5.11
I've always run this command to remove entries from the database:
/usr/bin/sqlite3 /etc/pihole/pihole-FTL.db "DELETE FROM queries WHERE client='192.168.10.51'"
I get the below error:
Error: cannot modify queries because it is a view
Did the command or process change for removing entries?
Thanks!
Joe
With the latest version the database schema has changed. The actual data is stored in the new table query_storage. The queries is a view only from which you can't delete queries anymore. Furthermore, the client information is not stored in query_storage as IP but rather an ID linked to the new client_by_id table.
You need to do two things now:
sqlite3 /etc/pihole/pihole-FTL.db "DELETE FROM query_storage WHERE client='192.168.10.51';"
To delete the remaining queries for 192.168.10.51 before the update.
From now on you need to perform:
sqlite3 /etc/pihole/pihole-FTL.db "DELETE FROM query_storage where client in (select id from client_by_id where ip='192.168.10.51');"
Thanks. I'll give it a shot shortly.
Joe
Clearly worked.
Biggest difference now is, you have to stop FTL prior to the delete. Not a big deal at all.
Joe
It worked, but the queries view table that is responsible for the top domains on web GUI did not change. How can I force the queries table to regenerate?
Try restating FTL.
I think you mean restarting FTL.
pihole restartdns does not help.
I tried to use the following command:
sudo service pihole-FTL stop && sudo sqlite3 pihole-FTL.db "delete from query_storage where domain='example.com';" ; pihole restartdns
But example.com still shows on the web gui.
Reboot does not help either.
Edit: I used a wrong command. See next reply.
I used a incorrect command. The new one should be this:
sudo service pihole-FTL stop && sudo sqlite3 pihole-FTL.db "delete from query_storage where domain in (select id from domain_by_id where domain like 'example.com');" ; pihole restartdns
