The issue I am facing:
I’ve been seeing intermittent delays in loading sites for some time now.
When I type in a browser search bar (any device, mac or ios) or click a link there is a several second delay before anything loads. Sometimes it’s up to 8-10 seconds.
Details about my system:
I have used PiHole in my current config for several years.
Topology:
Xfinity Modem > Firewalla Gold > Pi4 w/ Pihole on one Eth port as its own “Pihole”network segment (per Firewalla rec) which runs in the 192.168.1.x IP pool, and Eero Pro6 units in AP mode on another Eth port with a network segment I called “Home” which runs in the 192.168.2.x IP pool.
– Everything in Firewalla settings points all devices to DNS at 192.168.1.10 (my pi4).
– Pi has assigned IP at the Firewalla
– Cloudflare is set as the upstream DNS
– Pi runs Pihiole, PiVPN and Homebridge, don’t think it’s doing anything else as far as I recall.
– Everything up to date
Logs:
https://tricorder.pi-hole.net/OyzJL1cU/
Any suggestions related or unrelated to my issue are welcome and appreciated. Thank you.
