Data get reset after reboot of system or Pihole
That the data should be store in the database and that it should not be resetting back to 0 when i reboot the service or the VM.
When i reboot the computer or Pihole all the statistic data get deleted and it starting back on 0 again.
https://tricorder.pi-hole.net/oKXF9lG1/
I have try to pihole -r but that don't seems to be helping.
Seeing this errors in the error log
2023-09-23 09:20:08: (mod_fastcgi.c.451) FastCGI-stderr:PHP Warning: SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
2023-09-23 09:20:13: (mod_fastcgi.c.451) FastCGI-stderr:PHP Warning: SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
2023-09-23 09:25:29: (mod_fastcgi.c.451) FastCGI-stderr:PHP Warning: SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
2023-09-23 09:25:32: (mod_fastcgi.c.451) FastCGI-stderr:PHP Warning: SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
2023-09-23 09:25:34: (mod_fastcgi.c.451) FastCGI-stderr:PHP Warning: SQLite3::prepare(): Unable to prepare statement: 1, no such table: query_storage in /var/www/html/admin/api_db.php on line 94
2023-09-23 09:25:34: (mod_fastcgi.c.451) FastCGI-stderr:PHP Fatal error: Uncaught Error: Call to a member function bindValue() on bool in /var/www/html/admin/api_db.php:95
2023-09-23 09:25:34: (mod_fastcgi.c.451) FastCGI-stderr:Stack trace:
2023-09-23 09:25:34: (mod_fastcgi.c.451) FastCGI-stderr:#0 {main}
2023-09-23 09:25:34: (mod_fastcgi.c.451) FastCGI-stderr: thrown in /var/www/html/admin/api_db.php on line 95
2023-09-23 09:25:37: (mod_fastcgi.c.451) FastCGI-stderr:PHP Warning: SQLite3::query(): Unable to prepare statement: 1, no such table: message in /var/www/html/admin/api_db.php on line 385
Can that be related?
I manage to fix this my self whit following step.
cd /etc/pihole
sudo rm -r pihole-FTL.db
pihole -r
So it seems like maybe something got wrong during the pihole install.
Probably.
Your debug log shows the database was only 20Kb in size:
*** [ DIAGNOSING ]: Pi-hole FTL Query Database
-rw-rw-r-- 1 pihole pihole 20K Sep 16 17:04 /etc/pihole/pihole-FTL.db
Even a completely empty pihole-FTL database should be larger (around 80Kb). I think something went wrong during the database creation, leading to this error.
Glad you fixed!
Yes i thought so to. That`s why i posted how i fix it if someone else end up whit the same problem they could try this out to.
I had the mysterious phenomenon and used the same solution.
The error was solved and never occurred again.
