Custom block page is not working with v5.0
Please provide more information.
It simply times out , no custom page is displayed . I'm using the instructions provided as is . and using the IP blocking mode. Its on a throw away AWS machine
testing : blacklisted Weibo.com and fool.com for testing
On Safari : "Failed tot Open Page" generic message
On Chrome :
This site can’t be reached
weibo.com took too long to respond.
Try:
  • Checking the connection
  • Checking the proxy and the firewall
ERR_CONNECTION_TIMED_OUT
Is it publicly accessibly? Or behind a VPN?
Please provide a debug token - generated with pihole -d or via the web interface.
You should also be aware that the blocking page will only work for HTTP.
Increasing proliferation of HTTPS has been a main reason for Pi-hole to switch to NULL blocking as default.
https://tricorder.pi-hole.net/7jwy7fm1tg
I switched to NULL blocking , that only sped up the resolving to a site can't be reached error . still no block page got displayed
NULL disables the block page.
