Curl SSL error updating FTL
I just had a similar issue going from 4.2 to 4.2.1 and followed the same directions, it seems to be working here also. I received this message:
[i] FTL Checks...
[✓] Detected ARM-hf architecture (armv7+)
[i] Downloading and Installing FTL...curl: (56) SSL read: error:00000000:lib(0):func(0):reason(0), errno 104
Error: URL https://github.com/pi-hole/FTL/releases/download/v4.2.1/pihole-FTL-arm-linux-gnueabihf not found
[✗] FTL Engine not installed
While I don't find any issue with this being moved, my response was referencing the same commands for the previous issue worked for this issue also
Are you able to curl other URLs? If not, this may be a curl issue.
Edit: Make a debug token: pihole -d
