pihole -up are expected to be able to fetch latest FTL version, but it fails to verify SSL certificate lately, same goes for gravity updates thus it empties the blacklist
#uname -a
Linux raspberrypi 5.10.17+ #1421 Thu May 27 13:58:02 BST 2021 armv6l GNU/Linux
Adding -k to curl in /opt/pihole/gravity.sh fixes the gravity downloading though, but pihole -up seems to overwrite it self so same fix can't be applied here
#pihole -up
[i] Downloading and Installing FTL...curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: https://curl.haxx.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
Error: URL https://github.com/pi-hole/ftl/releases/latest/download/pihole-FTL-armv6-linux-gnueabihf not found
[✗] FTL Engine not installed
Found a valid 'DigiCert High Assurance EV Root CA' certificate from https://curl.se and store it into the ca-store this seems to have fixed the trust of github.com and githubusercontent.com again
Still wondering a bit as my other pi-hole instance seems to fetch more blacklisted domains from other sources than just from StevenBlack, as I remember it one of them was a list ending in '/domains'
This instance get me this only:
~# /opt/pihole/gravity.sh
[i] Using libz compression
[i] Analyzed 85386 domains
[i] List stayed unchanged
[i] Target: https://mirror1.malwaredomains.com/files/justdomains
[✗] Status: Not found
[✗] List download failed: no cached list available
[✓] Storing downloaded domains in new gravity database
[✓] Building tree
[✓] Swapping databases
[i] Number of gravity domains: 85386 (85386 unique domains)
[i] Number of exact blacklisted domains: 0
[i] Number of regex blacklist filters: 0
[i] Number of exact whitelisted domains: 5
[i] Number of regex whitelist filters: 2
[✓] Flushing DNS cache
[✓] Cleaning up stray matter
[✓] DNS service is listening
[✓] UDP (IPv4)
[✓] TCP (IPv4)
[✓] UDP (IPv6)
[✓] TCP (IPv6)
