Twice now I've run into trouble with my pi-hole server failing to deliver graphic data in the browser. The first time I largely 'gave up' and just re-installed. The second time I did some digging and determined it was the lighttpd server compression cache. Some of the js pages weren't getting compressed or sent properly. The side-effect was the browsers (chrome, ie, edge and firefox) all failing to show any graphs. Just the spinning arrow icons.
If I disabled the compression config lines in /etc/lighttpd/lighttpd.conf the problem goes away. If I manually delete the contents of /var/cache/lighttpd/compress it also solves the problem.
I've no idea how or why lighttpd suddenly decided to fail on just those files. I don't have enough logging data to tell me anything useful.
So I'm wondering if it might be useful to have either an automatic cron job or have it part of pi-hole's web UI to purge this data?
