Couldn't able to Block Ads with Primary and Secondary DNS
I performed a fresh installation of Pi-hole and Unbound DNS using DietPi. I have configured my router to use Pi-hole as the primary DNS, and when I set Cloudflare's DNS (1.1.1.1) as the secondary DNS, I'm not able to block ads. However, when I remove the secondary DNS, Pi-hole is able to block ads successfully.
The issue I am facing:
https://tricorder.pi-hole.net/jtUMArSR/
Details about my system:
DietPi running on NanoPi R6S
Fresh installation
Thank you
Have a look at below FAQ:
That bit about "Pi-hole and something else" could also apply for your router and is most likely what your experiencing.
