Correct syntax in dnsmasq entries
I'm using : Pi-hole Version** v4.4, Web Interface Version** v4.3.3, FTL Version** v4.3.1. in docker environment.
It just as simple setup as it can be.
I'd like to add static entries in ./etc-dnsmasq.d/99-hosts.conf file on host server.
But none of below entries is correct
Neither
mylocalserver1=/local/192.168.3.6
mylocalserver1=/3.168.192.in-addr.arpa/192.168.3.6
or
192.168.3.6    mylocalserver1.local   mylocalserver1
Every time i start container with custom dnsmasq file i receive this error:
"dnsmasq: bad option at line 1 of /etc/dnsmasq.d/99-hosts.conf"
I am not using DHCP in pi-hole. My local router (Archer C1200 v2.0) is also a DHCP server and does not have option to set "local" DNS domain in DHCP setting (but this shouldn't be as important, I think)
What am I doing wrong here?
That's not a dnsmasq configuration command.
What are you trying to accomplish?
I am trying to add few local servers to pi-hole DNS name resolution.
For example file share: fileserver with IP address: 192.168.3.34 and "myfileserver1".
address=/<domainname>/<IP>
So, this looks correct for me::
But does not work.
As noted by DanSchaper, this is not the correct format for the dnsmasq command:
Wrong:
mylocalserver1=/<domainname>/<IP>
Right:
Oh!
Thanks, this is simple as that :slight_smile:
