instead of lighttpd
Pihole core should update to 5.0.
pi@pi-hole:~ $ pihole -up
[i] Checking for updates...
error: refs/tags/2.0 does not point to a valid object!
error: refs/tags/2.8 does not point to a valid object!
error: refs/tags/V2.5.1 does not point to a valid object!
error: refs/tags/V2.9.1 does not point to a valid object!
error: refs/tags/V2.9.2 does not point to a valid object!
error: refs/tags/v2.1 does not point to a valid object!
error: refs/tags/v2.10 does not point to a valid object!
error: refs/tags/v2.10.1 does not point to a valid object!
error: refs/tags/v2.10.2 does not point to a valid object!
error: refs/tags/v2.11 does not point to a valid object!
error: refs/tags/v2.11.1 does not point to a valid object!
error: refs/tags/v2.11.2 does not point to a valid object!
error: refs/tags/v2.12 does not point to a valid object!
error: refs/tags/v2.12.1 does not point to a valid object!
error: refs/tags/v2.13 does not point to a valid object!
error: refs/tags/v2.13.1 does not point to a valid object!
error: refs/tags/v2.13.2 does not point to a valid object!
error: refs/tags/v2.2 does not point to a valid object!
error: refs/tags/v2.3 does not point to a valid object!
error: refs/tags/v2.4 does not point to a valid object!
error: refs/tags/v2.5 does not point to a valid object!
error: refs/tags/v2.5.2 does not point to a valid object!
error: refs/tags/v2.5.3 does not point to a valid object!
error: refs/tags/v2.6 does not point to a valid object!
error: refs/tags/v2.6.1 does not point to a valid object!
error: refs/tags/v2.6.1.1 does not point to a valid object!
error: refs/tags/v2.6.1.2 does not point to a valid object!
error: refs/tags/v2.6.2 does not point to a valid object!
error: refs/tags/v2.6.3 does not point to a valid object!
error: refs/tags/v2.7 does not point to a valid object!
error: refs/tags/v2.7.1 does not point to a valid object!
error: refs/tags/v2.8.1 does not point to a valid object!
error: refs/tags/v2.9 does not point to a valid object!
error: refs/tags/v2.9.3 does not point to a valid object!
error: refs/tags/v2.9.4 does not point to a valid object!
error: refs/tags/v2.9.4a does not point to a valid object!
error: refs/tags/v2.9.5 does not point to a valid object!
error: refs/tags/v3.0 does not point to a valid object!
error: refs/tags/v3.0.1 does not point to a valid object!
error: refs/tags/v3.1 does not point to a valid object!
error: refs/tags/v3.1.4 does not point to a valid object!
error: refs/tags/v3.2 does not point to a valid object!
error: refs/tags/v3.2.1 does not point to a valid object!
error: refs/tags/v3.3 does not point to a valid object!
error: refs/tags/v3.3.1 does not point to a valid object!
error: refs/tags/v4.0 does not point to a valid object!
error: refs/tags/v4.1 does not point to a valid object!
error: refs/tags/v4.1.1 does not point to a valid object!
error: refs/tags/v4.2 does not point to a valid object!
error: refs/tags/v4.2.1 does not point to a valid object!
error: refs/tags/v4.3 does not point to a valid object!
error: Could not read 1d43c0a2fa36ddc993db51b1751e26cbc8123fbf
fatal: pack has 75 unresolved deltas
fatal: index-pack failed
[i] Pi-hole Core: up to date
[i] Web Interface: up to date
[i] FTL: up to date
[✓] Everything is up to date!
When I ran this the first time, FTL and Web Interface updated to 5.0 but Core is stuck at 4.4. My UNeducated guess is that there is something wrong at github but what do I know.
https://tricorder.pi-hole.net/ztfsnmf9ab
windom
