Containerized Nginx Reverse Proxy issues
I am trying to setup a Pihole as my DHCP server behind an Nginx reverse proxy, both in Docker containers. So far, I've gotten Nginx reverse proxy manager up and running, and I can remotely connect to the GUI from my devices. The eventual goal is to get it running with SSL certs so I can tunnel in from outside, but for the time being I'm just trying to get things set up locally.
I'm still very new to networks and even this has pushed me beyond what I understand.
Doing my best to follow this thread, I ended up with this docker compose file for pihole.
services:
  pihole:
    container_name: pihole-relay
    image: pihole/pihole:latest
    ports:
      - "53:53/tcp"
      - "53:53/udp"
    restart: unless-stopped
    cap_add:
        - NET_ADMIN
    dns:
      - 127.0.0.1
      - 1.1.1.1
    environment:
      ServerIP: xxx.xxx.x.x # This is the RPi device's static IP
      DNS1: 1.1.1.1
      DNS2: 1.0.0.1
      VIRTUAL_HOST: pi.hole
      DNSMASQ_LISTENING: all
    volumes:
      - '/home/pihole/pihole/:/etc/pihole/'
      - '/home/pihole/dnsmasq.d/:/etc/dnsmasq.d/'
    depends_on:
      - dhcphelper
    networks:
      backend:
        ipv4_address: '172.31.0.100'
      nginx_default: {}
  dhcphelper:
    container_name: dhcp-relay
    build: ./dhcp-helper-1.2
    network_mode: "host"
    command: -s 172.31.0.100
    cap_add:
      - NET_ADMIN
networks:
  backend:
    ipam:
      config:
        - subnet: 172.31.0.0/16
  nginx_default:
    external: true
I then modified pihole.toml:
  etc_dnsmasq_d = true ### CHANGED, default = false
This brings the containers up and I'm not seeing any errors, but for the life of me I cannot figure out how to access the Pihole GUI, hook it up to Nginx, or get it actually work as the DHCP. I cannot access it directly via the 172.31.0.100 IP address, as that's internal to Docker's Pihole-backend network. There's another 172.22.0.1 IP internal to the nginx-proxy internal network that's listed in the inspect output as belonging to the pihole container. I get a ping response from both IPs from the RPi, but not when I ping from other devices.
I tried adding Pihole as a proxy host (see config file below), but I cannot access the domain I assigned it.
# nginx.pihole.slice
map $scheme $hsts_header {
    https   "max-age=63072000; preload";
server {
  set $forward_scheme http;
  set $server         "172.22.0.3";
  set $port           80;
  listen 80;
#listen [::]:80;
  server_name nginx.pihole.slice;
  http2 off;
  access_log /data/logs/proxy-host-2_access.log proxy;
  error_log /data/logs/proxy-host-2_error.log warn;
  location / {
    # Proxy!
    include conf.d/include/proxy.conf;
  # Custom
  include /data/nginx/custom/server_proxy[.]conf;
I'm fairly certain I'm ignorant of something obvious about how this entire system is supposed to work. My instinct is that I need to get Pihole's DNS working, but that seems redundant with the reverse proxy. I wanted to setting it as the DHCP server, but I'm not sure how to enable that from the CLI.
Notes about the compose file used:
You are using an outdated compose file.
These variables doesn't exist any more. They were removed.
This variable was replaced by FTLCONF_dns_listeningMode.
Please check the docker repository and our documentation:
