Connection refused
install pi hole on my pi zero w today. it shows that the connection refusion refused while downloading the adslist
os:raspberry pi os
[✗] Status: Connection Refused
[✗] List download failed: no cached list available
All the settings are in default . I also tried to install pi hole pi hole on a debian vm and faced the same issue.
I reply will be appreciated :smiling_face:
I am sure that internet is working and ping is working fine.
Debug token: [https://tricorder.pi-hole.net/e3Sc4sQw/ ](https://tricorder.pi-hole.net/e3Sc4sQw/
I can confirm that the list is available
I cant reach it with even a browser
This would indicate the problem is outside of Pi-hole.
Is that a problem with my country?
Yeah that file isnt accessable in india thank you so much👍
