Connection error: TCP connection failed (Operation in progress)
error appearing on fresh install of v6. it was never logged or reported in v5.
https://tricorder.pi-hole.net/2IDQnye8/
This was never reported in v5 because v5 didn't had the capability to report this kind of connection failure.
thanks for the clarification.
so that means i was having connection errors previously, but the errors were not being reported?
can you expand on WHY the connection is failing?
Probably.
Not really. The message is generated when Pi-hole expects an answer and nothing is returned, probably due to timeout, but there is no other information to describe what happened.
