CONNECTION_ERROR TCP connection failed (Operation in progress)
After upgrading to v6, I'm receiving the above error on both of my DNS servers.
Is the error reporting new?
I am seeing this as well after updating to v6
i never received a response to my log upload and im seeing the issue posted elsewhere. so for now, im staying with v5.
Apologies, we obviously missed your topic.
As usual, we have been quite busy answering questions after the new release.
Yes, it is.
The condition may have been present with v5 installations all along, but it wouldn't have been reported, and thus perhaps could be ignored.
But it may also have been triggered by pihole-FTL being based on the newest version of dnsmasq, which introduced a new mIxEd case/0x20 encoding feature which turned out to cause issues with certain upstream DNS services like cloudflared.
Even if you don't use cloudfared, please try setting misc.dnsmasq_lines under Settings | All settings » Miscellaneous to contain no-0x20-encode.
All settings is available in Expert mode only.
i made the changes about 20 hours ago. no issues before i went to sleep last night. but im seeing the connection error, consistently, again this am.
log below. thanks.
is this new reporting just the way it is moving forward?
am i actually experiencing connection errors?
mine also got updated to v6, and now getting this error
(it made my whole internet connection not to work, so I change the router dns to 1.1.1.1 for now)
I was seeing this a lot after upgrading to v6 (along with several other new errors). This morning I performed a fresh install and it looks much better and faster UX, but the operation in progress errors just started happening within an hour of the fresh install.
I just added the no-0x20-encode setting and will see if that improves.
Error continued after fresh install and adding no-0x20-encode to settings.
I've generated a log for review:
https://tricorder.pi-hole.net/nnKYgGAm/
