What device is it? Windows? Linux?
Add
Restart your router.
Add
It's the Mac Command killall -HUP mDNSResponder;sudo killall mDNSResponderHelper;sudo dscacheutil -flushcache I'll restart my router too
I don't have a mac,
let's see which DNS server your device is using.
cat /etc/resolv.conf
grep nameserver <(scutil --dns)
nameserver[0] : 8.8.8.8
nameserver[1] : 8.8.4.4
If this is the output from the Mac, the Mac is not using Pi-hole for DNS. It is using Google DNS.
The client can use Pi-hole DNS, but if your browser is configured to use a different DNS (i.e. DNS over HTTPS, a "feature" in Firefox and Chrome), then the browser traffice won't use the same DNS as the client and will bypass Pi-hole.
Is the RT-ACRH13 your only router in the network?
I found this, saying it hijacks DNS if in AP mode...
That fixed it!! ![]()
Yes, replace them with your pihole's IP.
Still wonder why the MAC doesn't use the DNS provided via DHCP....
What happens if you leave it empty there?
In case someone else stumbles upon this thread.
You should check these places:
If it's wrong in any one of these places, then the whole thing won't work.
That's what I did and I set configue ipv4 to Using DHCP
Glad it worked at the end.
Enjoy pihole.
