Hello, how do you configure two pi-hole instances?
In the case where the router is used as a DHCP server, I imagine that you simply have to put the two pi-hole IP addresses, but my first pi-hole instance serves as a DHCP server, do I have to put the second one in the DNS upstreams of the first one?
I have never used this kind of tools, in general I make a backup and I use the teleporter, with the passage from V5 to V6 and the big changes, in doubt I would start again on a clean base and make a backup as we do not know if it is 100% compatible, I use docker but it must be transportable on a bare metal
