Configurable Warnings in Pihole Diagnostics
i'd like to have an option to disable some warnings alltogether. Like this:
The reason is: In proxmox, when running in LXC this shows the load-average of the whole system. Same should be happening when run in docker and only be assigned a low number of CPU-Cores
This particular can be disabled
https://docs.pi-hole.net/ftldns/configfile/#check_load
