Can not use conditional forwarding. After I hit save, filled info will be lost
How can I switched it on thru conf file?
Please post the token generated by
Tools > Generate Debug Log
What information are you entering in the GUI for the conditional forwarding?
You need the local network in CIDR format - in your case this would be 192.168.1.0/24
The iP address of your router is 192.168.1.1
If you have a local domain name on your network (i.e. LAN, mynetwork, etc.), enter that.
This information is stored in file /etc/pihole/setupVars.conf. Your entries would look like this:
REV_SERVER=true
REV_SERVER_CIDR=192.168.1.0/24
REV_SERVER_TARGET=192.168.1.1
REV_SERVER_DOMAIN=
That exact information I'm entering. Still it is going to rewrite conf file and add CONDITIONAL_FORWARDING=false and all nothing wont stick to conf file thru WEB interface
Now I entered that directly to conf file and web interface shows it correctly
it should be 1.0 or 1.1?
That should be 1.1. I corrected my reply.
yes, now I insterted that to conf and thru web interface it shows correct. But it wont change it I want to disable or change it.
This problem occurs because command curl -sSL https://install.pi-hole.net | bash does not install pi-hole to Debian 10 correctly.
A post was split to a new topic: DNS settings won't save
