Conditional Forwarding not working
Display the hostnames of computers
Just getting ip's in place of hostnames.
https://tricorder.pi-hole.net/c64uk0cau2
so i have a TP-link Archer c7 v5 router and i was having this problem and decided to just take the leap and flash it with openwrt. This should have resolved it. despite reverse lookups working just fine from the command line to both the router and the pihole. i'm a little confused as to where to look.
root@pihole1:/etc/pihole# nslookup -x 192.168.0.2 192.168.0.1
2.0.168.192.in-addr.arpa name = shark.lan.
root@pihole1:/etc/pihole# nslookup -x 192.168.0.2 192.168.0.3
And below ?
nslookup -type=ptr 192.168.0.2
Make sure nameserver points to 127.0.0.1 where pihole-FTL is listening:
pi@noads:~ $ cat /etc/resolv.conf
nameserver 127.0.0.1
ok well the local resolver was set to google, i have reset it to localhost now.
but shouldn't this setting be overridder by the ip address in the dns settings for conditional forwarding?
root@pihole1:~# nslookup -type=ptr 192.168.0.2
Server:         8.8.8.8
Address:        8.8.8.8#53
** server can't find 2.0.168.192.in-addr.arpa: NXDOMAIN
root@pihole1:~# nano /etc/resolv.conf
Server:         127.0.0.1
Address:        127.0.0.1#53
ok that was resolved after i restarted pihole-FTL. that's still an odd bug. thank you very much for the help!
dhcpcd5 should populate resolv.conf through resolvconf:
