_Only 172.17.01, 127.0.0.1 and 172.17.0.2 show up. However, under query log I do see web traffic that I am going to on my computer (not the one running docker and pi-hole) When I run nslookup pi.hole I see:
_Server: Unkown
Address. 192.168.0.99 (this is the static IP of the windows machine running docker)
Address: 192.168.0.99
_https://tricorder.pi-hole.net/WXbgyrjJ/
Please, post the compose file or docker run
command used to start your container.
rdwebdesign:
docker run
docker run
--hostname=6089dd914269
--mac-address=02:42:ac:11:00:02
--env=DNS2=1.1.1.1
--env=DNS3=1.0.0.1
--env=ServerIP=192.168.0.99
--env=WEBPASSWORD=password
--env=TZ=America/Chicago
--env=DNS1=127.0.0.1
--env=PATH=/opt/pihole:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
--env=phpver=php
--env=PHP_ERROR_LOG=/var/log/lighttpd/error-pihole.log
--env=IPv6=True
--env=S6_KEEP_ENV=1
--env=S6_BEHAVIOUR_IF_STAGE2_FAILS=2
--env=S6_CMD_WAIT_FOR_SERVICES_MAXTIME=0
--env=FTLCONF_LOCAL_IPV4=0.0.0.0
--env=FTL_CMD=no-daemon
--env=DNSMASQ_USER=pihole
-p 443:443
-p 53:53
-p 53:53/udp
-p 80:80
--restart=unless-stopped
--label='org.opencontainers.image.created=2023-11-21T20:19:21.749Z'
--label='org.opencontainers.image.description=Pi-hole in a docker container'
--label='org.opencontainers.image.licenses=NOASSERTION'
--label='org.opencontainers.image.revision=184b8bbedcbf308a1777ed653f4a7cbc5885358d'
--label='org.opencontainers.image.source=GitHub - pi-hole/docker-pi-hole: Pi-hole in a docker container'
--label='org.opencontainers.image.title=docker-pi-hole'
--label='org.opencontainers.image.url=GitHub - pi-hole/docker-pi-hole: Pi-hole in a docker container'
--label='org.opencontainers.image.version=2023.11.0'
--runtime=runc
-d
pihole/pihole:latest
system
Closed
December 21, 2023, 6:13pm
4
