Commonly blacklisted domains
I don't think it's a tracking domain, https://forums.geforce.com/default/topic/857331/stop-geforce-experience-from-updating/
I did some experimenting tonight with my LG Smart TV and this is the list of servers I found that could be blacklisted:
These block ads in the LG App Store
  • lgad.cjpowercast.com.edgesuite.net
  • us.ad.lgsmartad.com
  • us.info.lgsmartad.com
This blocks the ads that show up here: https://i.imgur.com/2TKYBf5.png
  • ngfts.lge.com
It has some trade-offs, though.
  1. You have to allow it in order to sign any EULA agreements and to download apps. Doing so makes the ads appear, but turning the TV off (standby) and on again with the site re blacklisted clears them.
  2. The App icons and screenshots IN THE APP STORE would not appear.
This was not a huge loss because LG's app store is tiny. Every other smart TV feature works.
All4 Block Video Ads
cdn.ss.anno.channel4.com
Blocking ITV Hub Player Advertisements
Block the following domains.
tom.itv.com
They seem to have changed their advert server.
Blocking:
toots-a.akamaihd.net
Now does the trick instead. Stops the Windows desltop browser version of ITV Hub working, but skipsads on my Samsung smart TV & Fire TV.
A list for sites that use Miners it a google doc so highlight the A column and Crtl + C .
Miners spreadsheet
Not sure how to add to the original post but I've found blocking: logs.roku.com rather than more specific names helpful. I have >7000 hits to austin.logs.roku.com in the last 24 hours.
Outside of that:
captive.roku.com can be safely blocked if you don't need captive portal support (i.e. Hotel or Dorm connect: https://www.reddit.com/r/Roku/comments/3ppa7k/roku_has_added_captive_portal_support/)
And... victoria.logs.roku.com has started appearing on mine. Blocked.
A post was split to a new topic: Omit Blocked Domain From Logs
Block My5 TV app ads
nqs.nice264.com
mtv.hb.omtrdc.net
jwpltx.com
entitlements.jwplayer.com
ssl.p.jwpcdn.com
pasta.esfile.duapps.com
It seems like Reddit's invasive tracking should be blocked - see https://smitop.com/post/reddit-whiteops/ for details.
Block
  • vprza.com
  • minkatu.com
Here are some sites I have seen recently:
My FireStick has been calling out to avs-alexa-18-na.amazon.com
My Roku has been calling out to scribe.logs.roku.com
Edit: Both blocked without loss of functionality.
Blacklisting tracking.miui.com results in the Xiaomi Home app not showing the cleaning map for the Roborock Vacuum Cleaner. I'm not sure what else is going via that subdomain, but blacklisting it definitely stops part of the app from working. Not a huge loss, but maybe it shouldn't be blacklisted?
Note that the vacuum is still able to send the map data to Xiaomi, but you can't see it. So if the aim is to stop Xiaomi devices from phoning home, that didn't work.
Tiktok blocklist for our children, confirmed working on their Mobile phone.
https://raw.githubusercontent.com/danhorton7/pihole-block-tiktok/main/tiktok.txt
