I have a lot of comments in my pihole-FTL.conf, mainly to identify undocumented settings or point to topics where the setting is introduced / explained
one of my comments triggered a php error on the settings page
Actually, FTL does not care about #. Instead, everything FTL cannot parse as valid config setting is ignored. So using ; everywhere is fine as well. Prepending with ä would equally work, too, etc.
Additional hint: Pi-hole v6.0 will change the config file format to TOML. The existing pihole-FTL.conf file will be automatically rewritten into a TOML document. Existing comments will be lost but the new file will contain comments for everything, for instance:
# This file is managed by pihole-FTL
# Do not edit the file while FTL is
# running or your changes may be overwritten
# Last update: 2021-06-10 12:09:06
[dns]
# How should FTL reply to blocked queries?
# Possible values are: [ "NULL", "IP-NODATA-AAAA", "IP", "NXDOMAIN" ]
blockingmode = "NULL"
# Should FTL walk CNAME paths?
CNAMEdeepInspect = true
# Should _esni. subdomains be blocked by default?
blockESNI = true
# Should FTL analyze possible ECS information to obtain client IPs hidden behind NATs?
EDNS0ECS = true
# Should FTL hide queries made by localhost?
ignoreLocalhost = false
[dns.ipBlocking]
# Use a specific IPv4 address in IP blocking mode
# Possible values are: <valid IPv4 address> or empty string ("")
IPv4 = ""
# Use a specific IPv6 address in IP blocking mode
# Possible values are: <valid IPv6 address> or empty string ("")
IPv6 = ""
[dns.rateLimit]
# How many queries are permitted...
count = 0 ### CHANGED, default = 1000
# ..in the set interval before rate-limiting?
interval = 0 ### CHANGED, default = 60
[resolver]
# Should FTL try to resolve IPv4 addresses to hostnames?
resolveIPv4 = true
# Should FTL try to resolve IPv6 addresses to hostnames?
resolveIPv6 = true
# Try to obtain client names from the network table
networkNames = true
# How (and if) hourly PTR lookups should be made
# Possible values are: [ "IPV4_ONLY", "ALL", "UNKNOWN", "NONE" ]
refresh = "IPV4_ONLY"
[database]
# Should FTL load information from the database on startup to be aware of the most recent history?
DBimport = true
# How much history should be imported from the database [seconds]? (max 24*60*60 = 86400)
maxHistory = 86400
# How long should queries be stored in the database [days]?
maxDBdays = 365
# How often do we store queries in FTL's database [seconds]?
DBinterval = 60
[database.network]
# Should FTL anaylze the local ARP cache?
parseARP = true
# How long should IP addresses be kept in the network_addresses table [days]?
expire = 365
[http]
# Does local clients need to authenticate to access the API?
localAPIauth = true
# Should FTL insert extra spaces to prettify the API output?
prettyJSON = false
# How long should a session be considered valid after login [seconds]?
sessionTimeout = 300
# On which domain is the web interface served?
# Possible values are: <valid domain>
domain = "pi.hole"
# Webserver access control list.
# Possible values are: <valid ACL>
acl = "+0.0.0.0/0"
# Ports to be used by the webserver
# Possible values are: list of <[ip_address:]port>
port = "8080,[::]:8080"
[http.paths]
# Server root on the host
# Possible values are: <valid path>
webroot = "/var/www/html"
# Sub-directory of the root containing the web interface
# Possible values are: <valid subpath>, both slashes are needed!
webhome = "/admin/"
[files]
# The location of FTL's log file
# Possible values are: <any writable file>
log = "/var/log/pihole-FTL.log"
# The location of FTL's PID file
pid = "/run/pihole-FTL.pid"
# The location of FTL's long-term database
# Possible values are: <any FTL database>
database = "/etc/pihole/pihole-FTL.db"
# The location of Pi-hole's gravity database
# Possible values are: <any gravity database>
gravity = "/etc/pihole/gravity.db"
# The database containing MAC -> Vendor information for the network table
# Possible values are: <any macvendor database>
macvendor = "/etc/pihole/macvendor.db"
# The config file of Pi-hole
# Possible values are: <any setupVars file>
setupVars = "/etc/pihole/setupVars.conf"
# The log file used by the webserver
# Possible values are: <any writable database>
HTTPinfo = "/var/log/pihole/HTTP_info.log"
# The log file used by the dynamic interpreter PH7
PH7error = "/var/log/pihole/PH7.log"
[misc]
# Privacy level
privacyLevel = 0
# Set niceness of pihole-FTL (can be disabled by setting to -999)
nice = -30 ### CHANGED, default = -10
# Artificially delay FTL's startup (0 to 300 seconds)
delayStartup = 0
[debug]
# Temporarily enable all debug flags
all = false
# Enable extra logging of database actions
database = false
# Enable extra logging of detected interfaces
networking = false
# Enable extra logging of shared memory lock actions
locks = false
# Print extensive query information
queries = true ### CHANGED, default = false
# Print flags of queries received by the DNS hooks
flags = true ### CHANGED, default = false
# Print information about shared memory buffers
shmem = true ### CHANGED, default = false
# Print information about garbage collection
gc = false
# Print information about ARP table processing
arp = false
# Enable extra logging of regex matching details
regex = false
# Enable extra logging of API activities
api = true ### CHANGED, default = false
# Print information about overTime memory operations
overtime = false
# Enable extra logging of query status changes
status = true ### CHANGED, default = false
# Print information about capabilities granted to the pihole-FTL process
caps = false
# Enable extra logging in dnsmasq's log routine
dnsmasq_lines = false
# Print vector operation details
vectors = false
# Extensive information about hostname resolution like which DNS servers are used
resolver = true ### CHANGED, default = false
# Print EDNS(0) debugging information
edns0 = false
# Enable extra client detail logging
clients = false
# Print aliasclient details
aliasclients = false
# Log information about processed internal events
events = true ### CHANGED, default = false
# Enable logging of script helper activity
helper = false
# Print config parsing details
config = true ### CHANGED, default = false
You can see that FTL will automatically add comments to changed values to highlight that they were changed and also mentioning what the default value would have been. The file above is what my current Pi-hole v6.0 development machine uses. The format is by no means fixed and may change until we're ready for public testing.
don't think this is a good idea (using anything else but a leading '#')
reason, scripts don't like this...
from query.sh
piholeDir="/etc/pihole"
# Source pihole-FTL from install script
pihole_FTL="${piholeDir}/pihole-FTL.conf"
if [[ -f "${pihole_FTL}" ]]; then
source "${pihole_FTL}"
fi
result (tested change on single line, using '//')
/etc/pihole/pihole-FTL.conf: line 32: //GRAVITYDB=/etc/pihole/gravity.db: No such file or directory
