Please ensure that you are running the latest version of the beta code. Run pihole -up to update to the latest, then verify that the problem still exists before reporting it.
Problem with Beta 5.0:
Links to link.freebooksy.com are not decoding to 162.208.117.53 (found via nslookup on 8.8.8.8)
dig link.freebooksy.com
link.freebooksy.com. 0 IN CNAME cb.sailthru.com.
cb.sailthru.com. 0 IN CNAME link-nj1.sailthru.com.
link-nj1.sailthru.com. 0 IN A 162.208.117.53
I'm going to guess that the CNAMEs are on the list of domains to be blocked.
@hairybiker If you have the web interface http://pi.hole/admin installed, you can go to the Query Log which will directly show you which of the domains along the CNAME path was blocked. Else you can do what Dan suggested and query the blocking lists for the contained domains.
Deep CNAME inspection is a new feature that comes with v5.0. It will help to block ads covering under CNAMEs.
That was the o/p. Direct copy paste @jfb I DON'T want to block them they link to Amazon ebooks.
As I said it was working perfectly before upgrading to 5.0.
Today the website is doing direct links to Amazon, yesterday it was via link.freebooksy.com @DL6ER
root@PiHole:~# pihole -v
Pi-hole version is v4.3.2-421-gb73580f (Latest: v4.3.2)
AdminLTE version is v4.3.2-426-gdd7b2b2 (Latest: v4.3.3)
FTL version is vDev-61d67ff (Latest: v4.3.1)
$ pihole -q cb.sailthru.com
Match found in https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts:
cb.sailthru.com
$ pihole -q link-nj1.sailthru.com
[i] No results found for link-nj1.sailthru.com within the block lists
Can confirm sailthru.com is on Steven Black's master list:
ak.sailthru.com
api.sailthru.com
cb.sailthru.com
cdn.sailthru.com
condenast-a.sailthru.com
condenast-b.sailthru.com
condenast-c.sailthru.com
horizon.sailthru.com
horizon-nj1.sailthru.com
njmta-173.sailthru.com
ny1mta-31.sailthru.com
ny1mta-56.sailthru.com
ny1mta-58.sailthru.com
Match found in https://hosts-file.net/ad_servers.txt:
cdn.sailthru.com
I am a bit dyslexic so my fault I mistyped
but " link does but it points to a domain you’ve asked Pi-hole to block." I am NOT asking to BLOCK it but to ALLOW it.
2020-02-21 17:52:50 A link.freebooksy.com octo.lan Unknown (9) CNAME (48.1ms)
