instead of lighttpd
When setting the DNS server to 127.0.0.1#5053, I expected the cloudflared service to work as intended.
When using cloudflared as the DNS service, I could not connect to any external websites. When I tried to run dig @127.0.0.1 -p 5053 google.com
, it returned:
; <<>> DiG 9.18.28-1~deb12u2-Debian <<>> @127.0.0.1 -p 5053 google.com
; (1 server found)
;; ->>HEADER<<- opcode: QUERY, status: SERVFAIL, id: 27472
;; flags: qr rd; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; WARNING: recursion requested but not available
; COOKIE: 7abbdbb4ecbc8a6c (echoed)
;google.com. IN A
;; Query time: 8 msec
;; SERVER: 127.0.0.1#5053(127.0.0.1) (UDP)
;; WHEN: Sat Dec 28 02:06:43 PST 2024
;; MSG SIZE rcvd: 51
So I'm assuming something is wrong with cloudflared, because if I use the default Cloudflare DNS (1.1.1.1
, 1.0.0.1
), it works perfectly fine.
