Cloudflared (DoH) resolving addresses that are blocked by 1.1.1.3
Hello,
This is an interesting one...
I tried switching config.yml in cloudflared from Cloudflare's main DNS server (1.1.1.1) to their Cloudflare DNS for Families setting of 1.1.1.3.
proxy-dns: true
proxy-dns-port: 5053
proxy-dns-upstream:
The tunnel works and DNS resolution works, but the Pi-hole is not blocking. When going directly to Cloudflare it blocks it correctly.
I've included the nslookup results below.
Cloudflare was setup per the instructions here: cloudflared (DoH) - Pi-hole documentation
PS H:> nslookup pornhub.com 192.168.2.108
Server: pi.hole
Address: 192.168.2.108
Non-authoritative answer:
Address: 66.254.114.41
PS H:> nslookup pornhub.com 1.1.1.3
Server: UnKnown
Address: 1.1.1.3
Addresses: ::
0.0.0.0
I am really stumped on this one and would appreciate any help.
Thanks.
Ok, I resolved the issue.
Here is the resolution for those running into the same issue.
In config.yml, you must configure the file to look like this:
proxy-dns: true
proxy-dns-upstream:
The resolution was found here:
https://developers.cloudflare.com/1.1.1.1/1.1.1.1-for-families#dns-over-https-doh
Thanks.
