Clients listed as "dsldevice.lan" instead of client name
I have pi-hole 5.18.2 installed on a Raspberry Pi 4B running 6.6.20+rpt-rpi-v8; my devices all use the cable router (192.168.1.1) for DNS, and the cable router is configured to use the static address of my Pi-Hole Raspberry Pi. It is working to block ads to my devices.
When I view the Query Log in the Pi-Hole admin screen, I expect to see some useful name in the "Client" column.
Instead, all clients are named "dsldevice.lan"
This would appear to be expected behavior given how you've set it up; your router is providing DNS for all your clients, and Pihole is providing DNS for your router. Therefore, the Pihole sees the router as its only client.
To get the "expected behavior," you'll want to either manually configure each client to use Pihole for DNS, or configure DHCP to provide Pihole's IP as the DNS for your network.
