I am trying to set up my kids' laptops as clients so that I can apply settings from a kid specific group. After trying to figure out why the groups where working on my laptop and not on the kids, I realized the difference is that all of the kids' laptops are connected to a wifi extender.
Their laptops see the PiHole, but the PiHole can't seem to properly identify them on the client list.
I am running the current dev branch of PiHole, so that I can ID clients by MAC address. The PiHole is set up as the DHCP server and the wifi extender has a DCHP static reservation.
Router DCHP server is turned off.
The wifi extender is also using a static ip configuration, and broadcasts the same SSID as the router
Static IP: 192.168.1.235 (same as the DHCP reservation)
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.1.1 (router)
DNS: 192.168.1.233
Expected behavior is that the PiHole identifies the clients at any point on the network, whether connecting to the router or the extender.
Clients connected to the extender can see the pi, and have the default group blocking. But, assigning these clients to another group doesn't have any effect.
https://tricorder.pi-hole.net/b381f1lim0
edit
I had to change the extender setting to automatic DHCP to get certain devices to work
solution
So, pihole didn't like the assignment of both groups to a given client. I think there was a conflict between the Default whitelist and the School blacklist. Assigned all domains/adlists to all groups, and then specifically edited the domains I wanted blacklisted on only School and whitelisted on only Default
