I'm running pihole on docker with dhcp enabled for ipv4 behind an openwrt-router.
I have multiple groups and want all client-hosts to be recognized for both ipv4 and ipv6 and do correct filtering.
I have a single pixel-phone in my environment which is sending DNS-requests solely using its constantly changing (privacy enhanced) IPv6-adresses. In the first run these can't be assigned to a specific mac or host, which shows in the FTL.log:
[2023-04-15 15:12:29.095 267M] Querying gravity database for client with IP fd51:....:e720...
[2023-04-15 15:12:29.096 267M] --> No record for fd51:....:e720 in the client table
[2023-04-15 15:12:29.096 267M] Querying gravity database for MAC address of fd51:....:e720...
[2023-04-15 15:12:29.096 267M] --> No result.
[2023-04-15 15:12:29.097 267M] Querying gravity database for host name of fd51:....:e720...
[2023-04-15 15:12:29.098 267M] --> No result.
[2023-04-15 15:12:29.098 267M] Querying gravity database for interface of fd51:....:e720...
[2023-04-15 15:12:29.099 267M] --> No result.
[2023-04-15 15:12:29.099 267M] Gravity database: Client fd51:....:e720 not found. Using default group.
After some time I get these messages in the log:
[2023-04-15 15:17:25.737 267M] Reloading client groups after 296 seconds (3rd check)
[2023-04-15 15:17:25.737 267M] Querying gravity database for client with IP fd51:....:e720...
[2023-04-15 15:17:25.738 267M] --> No record for fd51:....:e720 in the client table
[2023-04-15 15:17:25.738 267M] Querying gravity database for MAC address of fd51:....:e720...
[2023-04-15 15:17:25.739 267M] --> Querying client table for c8:2a:dd:86:f7:71
[2023-04-15 15:17:25.740 267M] --> Found record for c8:2a:dd:86:f7:71 in the client table (group ID 47)
[2023-04-15 15:17:25.740 267M] Querying gravity database for client fd51:....:e720 (getting groups)
[2023-04-15 15:17:25.740 267M] Gravity database: Client c8:2a:dd:86:f7:71 found. Using groups (2)
But this does not help the actual recognition. The requests are still failing, because the filtering is still performed using the default group.
Debug Token: https://tricorder.pi-hole.net/3lPHmU0f/
