using newest Pi-Hole FLT v6.0.4, Web v6.0.2 and Core v6.0.5
Description offers: " Clients may be described either by their IP addresses (IPv4 and IPv6 are supported), IP subnets (CIDR notation, like 192.168.2.0/24 ), their MAC addresses (like 12:34:56:78:9A:BC ), "
It is not possible to add clients using IP address or subnet in CDIR notation.
Just a warning is presented: Warning - please enter an IP or Mac address
I presume, that the client has to be known by its MAC address even when the IP address is used to specify the client (why: client IP address was not accepted 3-4 time, then suddenly it was accepted, trying subnet in CDIR still not working).
Sorry to bother you with this question.
In the meantime with some try-and-error I found a "solution" aka workaround aka "user error?".
Using the TAB function or selecting another input filed, after typing the IP address, clears the address input field.
Workaround: the highlighted field below the address input field shows a copy of the entered address/subnet, if selected with mouse/touch, everything works fine.
Maybe adding a comment that a user must select the highlighted field would be helpful around this unusual behaviour.
Thank your much for your support!
RG
Harald
