Hello @jfb ,
I generated the debug log by Tools >Generate Debug Log, but don't know how to get the token.
Please see below, thank you.
root@pihole:~# cat /var/log/pihole_debug.log
This process collects information from your Pi-hole, and optionally uploads it to a unique and random directory on tricorder.pi-hole.net.
The intent of this script is to allow users to self-diagnose their installations. This is accomplished by running tests against our software and providing the user with links to FAQ articles when a problem is detected. Since we are a small team and Pi-hole has been growing steadily, it is our hope that this will help us spend more time on development.
*** [ INITIALIZING ]
[i] 2021-08-31:22:25:15 debug log has been initialized.
[i] Core: v5.3.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Remotes: origin https://github.com/pi-hole/pi-hole.git (fetch)
origin https://github.com/pi-hole/pi-hole.git (push)
[i] Branch: master
[i] Commit: v5.3.1-0-g4736e03
[i] Web: v5.5.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Remotes: origin https://github.com/pi-hole/AdminLTE.git (fetch)
origin https://github.com/pi-hole/AdminLTE.git (push)
[i] Branch: master
[i] Commit: v5.5.1-0-gfb9bd56
[✓] FTL: v5.8.1
[i] 1.4.53
[i] 7.3.29
[i] dig return code: 0
[i] dig response: "Raspbian=9,10 Ubuntu=16,18,20 Debian=9,10 Fedora=32,33 CentOS=7,8"
[✓] Distro: Debian
[✓] Version: 10
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: FirewallD
[i] Firewalld service inactive
*** [ DIAGNOSING ]: Processor
[✓] x86_64
[✓] IPv4 address(es) bound to the ens18 interface:
10.0.0.100/24 matches the IP found in /etc/pihole/setupVars.conf
[✓] IPv6 address(es) bound to the ens18 interface:
fe80::882f:33ff:fe41:3471 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 10.0.0.3
* Pinging 10.0.0.3...
[✓] Gateway responded.
*:22 sshd (IPv4)
*:22 sshd (IPv6)
[80] is in use by lighttpd
[53] is in use by pihole-FTL
[✗] Failed to resolve via localhost (127.0.0.1)
[✗] Failed to resolve via Pi-hole (10.0.0.100)
[✓] doubleclick.com is 172.217.13.110 via a remote, public DNS server (8.8.8.8)
Timeout: 10 seconds
* Received 300 bytes from ens18:10.0.0.3
Offered IP address: 10.0.0.100
Server IP address: N/A
Relay-agent IP address: N/A
BOOTP server: (empty)
BOOTP file: (empty)
DHCP options:
Message type: DHCPOFFER (2)
server-identifier: 10.0.0.3
lease-time: 7200 ( 2h )
netmask: 255.255.255.0
router: 10.0.0.3
dns-server: 10.0.0.100
dns-server: 1.1.1.1
hostname: "pihole"
domain-name: "5net.net"
--- end of options ---
DHCP packets received on interface ens18: 1
[✓] lighttpd daemon is active
*** [ DIAGNOSING ]: Pi-hole-FTL full status
Active: active (exited) since Tue 2021-08-31 17:59:18 EDT; 4h 26min ago
Process: 19005 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Aug 31 17:59:18 pihole systemd[1]: pihole-FTL.service: Succeeded.
Aug 31 17:59:18 pihole systemd[1]: Stopped LSB: pihole-FTL daemon.
Aug 31 17:59:18 pihole systemd[1]: Starting LSB: pihole-FTL daemon...
Aug 31 17:59:18 pihole pihole-FTL[19005]: Not running
Aug 31 17:59:18 pihole su[19023]: (to pihole) root on none
Aug 31 17:59:18 pihole su[19023]: pam_unix(su:session): session opened for user pihole by (uid=0)
Aug 31 17:59:18 pihole pihole-FTL[19005]: FTL started!
Aug 31 17:59:18 pihole su[19023]: pam_unix(su:session): session closed for user pihole
Aug 31 17:59:18 pihole systemd[1]: Started LSB: pihole-FTL daemon.
PIHOLE_INTERFACE=ens18
IPV4_ADDRESS=10.0.0.100/24
IPV6_ADDRESS=
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
CACHE_SIZE=10000
ADMIN_EMAIL=
WEBUIBOXEDLAYOUT=boxed
WEBTHEME=default-light
BLOCKING_ENABLED=true
HTTP/1.1 200 OK
Expires: Wed, 01 Sep 2021 02:25:25 GMT
Cache-Control: max-age=0
Date: Wed, 01 Sep 2021 02:25:25 GMT
Server: lighttpd/1.4.53
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
*** [ DIAGNOSING ]: Gravity List and Database
-rw-rw-r-- 1 pihole pihole 5332992 Aug 31 22:23 /etc/pihole/gravity.db
*** [ DIAGNOSING ]: Info table
property value
version 14
updated 1630446708
gravity_count 0
Last gravity run finished at: Tue Aug 31 17:51:48 EDT 2021
----- First 10 Gravity Domains -----
*** [ DIAGNOSING ]: Groups
id enabled name date_added date_modified description
0 0 XDefault 2021-08-30 23:40:39 2021-08-31 17:28:13 The default group
1 1 plogan 2021-08-30 23:55:07 2021-08-31 17:36:01 plogan
5 1 Hannah 2021-08-30 23:55:30 2021-08-31 17:35:58 Hannah
6 1 Coca 2021-08-30 23:55:34 2021-08-31 17:35:56 Coca
7 1 CCTV 2021-08-30 23:55:51 2021-08-31 17:35:53 CCTV
8 1 DoorLock 2021-08-30 23:55:56 2021-08-31 17:35:50 DoorLock
9 1 Server 2021-08-30 23:56:02 2021-08-31 17:35:46 Server
10 1 Laura Thuy Khanh 2021-08-30 23:56:38 2021-08-31 17:35:41 ThuyKhanh
*** [ DIAGNOSING ]: Clients
id group_ids ip date_added date_modified comment
1 0 A4:E4:B8:65:FE:2B 2021-08-30 23:56:59 2021-08-31 22:23:30 plogan's blackberry
2 0 F0:18:98:32:87:AC 2021-08-31 17:27:42 2021-08-31 17:27:42 ThuyKhanh-MacBookPro
*** [ DIAGNOSING ]: Adlists
id enabled group_ids address date_added date_modified comment
1 1 0 https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts 2021-08-30 23:40:39 2021-08-30 23:40:39 Migrated from /etc/pihole/adlists.list
-rw-r--r-- 1 root root 37 Aug 31 17:51 /etc/pihole/local.list
10.0.0.100 pihole
10.0.0.100 pi.hole
-rw-r--r-- 1 root root 234 Aug 30 23:40 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-rw-r-- 1 pihole root 15 Aug 30 23:40 /etc/pihole/pihole-FTL.conf
PRIVACYLEVEL=0
-rw-r--r-- 1 root root 1386 Aug 30 23:40 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=8.8.8.8
server=8.8.4.4
interface=ens18
server=/use-application-dns.net/
-rw-r--r-- 1 root root 0 Aug 30 23:40 /etc/lighttpd/external.conf
-rw-r--r-- 1 root root 4066 Aug 30 23:40 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "/pihole/index.php"
server.pid-file = "/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = (
"application/json",
"application/vnd.ms-fontobject",
"application/xml",
"font/eot",
"font/opentype",
"font/otf",
"font/ttf",
"image/bmp",
"image/svg+xml",
"image/vnd.microsoft.icon",
"image/x-icon",
"text/css",
"text/html",
"text/javascript",
"text/plain",
"text/xml"
mimetype.assign = (
".ico" => "image/x-icon",
".jpeg" => "image/jpeg",
".jpg" => "image/jpeg",
".png" => "image/png",
".svg" => "image/svg+xml",
".html" => "text/html; charset=utf-8",
".js" => "text/javascript; charset=utf-8",
".json" => "application/json; charset=utf-8",
".map" => "application/json; charset=utf-8",
".txt" => "text/plain; charset=utf-8",
".eot" => "application/vnd.ms-fontobject",
".otf" => "font/otf",
".ttc" => "font/collection",
".ttf" => "font/ttf",
".woff" => "font/woff",
".woff2" => "font/woff2"
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ "\.(eot|otf|tt[cf]|woff2?)$" {
url.access-deny = ("")
expire.url = ( "" => "access plus 0 seconds" )
-rw-r--r-- 1 root root 1755 Aug 30 23:40 /etc/cron.d/pihole
26 3 * * 7 root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker local
25 14 * * * root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/sbin:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 214 Aug 30 23:40 /var/log/lighttpd/error.log
-----head of error.log------
2021-08-30 23:40:24: (server.c.1464) server started (lighttpd/1.4.53)
2021-08-30 23:40:38: (server.c.2059) server stopped by UID = 0 PID = 1
2021-08-30 23:40:38: (server.c.1464) server started (lighttpd/1.4.53)
-----tail of error.log------
-rw-r--r-- 1 pihole pihole 32750 Aug 31 22:23 /var/log/pihole-FTL.log
[2021-08-31 00:14:46.944 11828M] New upstream server: 8.8.8.8:53 (1/512)
[2021-08-31 00:14:57.285 11828M] Resizing "FTL-dns-cache" from 16384 to (1280 * 16) == 20480 (/dev/shm: 786.4KB used, 517.6MB total, FTL uses 774.4KB)
[2021-08-31 00:24:15.206 11828M] Resizing "FTL-dns-cache" from 20480 to (1536 * 16) == 24576 (/dev/shm: 790.5KB used, 517.6MB total, FTL uses 778.5KB)
[2021-08-31 00:27:39.478 11828M] Resizing "FTL-queries" from 262144 to (8192 * 64) == 524288 (/dev/shm: 794.6KB used, 517.6MB total, FTL uses 782.6KB)
[2021-08-31 01:13:09.960 11828M] Resizing "FTL-dns-cache" from 24576 to (1792 * 16) == 28672 (/dev/shm: 1.1MB used, 517.6MB total, FTL uses 1.0MB)
[2021-08-31 01:25:19.994 11828M] Resizing "FTL-queries" from 524288 to (12288 * 64) == 786432 (/dev/shm: 1.1MB used, 517.6MB total, FTL uses 1.0MB)
[2021-08-31 02:21:09.404 11828M] Resizing "FTL-queries" from 786432 to (16384 * 64) == 1048576 (/dev/shm: 1.3MB used, 517.6MB total, FTL uses 1.3MB)
[2021-08-31 02:44:21.604 11828M] Resizing "FTL-dns-cache" from 28672 to (2048 * 16) == 32768 (/dev/shm: 1.6MB used, 517.6MB total, FTL uses 1.6MB)
[2021-08-31 02:59:35.722 11828M] Resizing "FTL-domains" from 24576 to (1536 * 24) == 36864 (/dev/shm: 1.6MB used, 517.6MB total, FTL uses 1.6MB)
[2021-08-31 03:19:24.356 11828M] Resizing "FTL-queries" from 1048576 to (20480 * 64) == 1310720 (/dev/shm: 1.6MB used, 517.6MB total, FTL uses 1.6MB)
[2021-08-31 04:13:37.489 11828M] Resizing "FTL-dns-cache" from 32768 to (2304 * 16) == 36864 (/dev/shm: 1.9MB used, 517.6MB total, FTL uses 1.9MB)
[2021-08-31 04:28:37.230 11828M] Resizing "FTL-queries" from 1310720 to (24576 * 64) == 1572864 (/dev/shm: 1.9MB used, 517.6MB total, FTL uses 1.9MB)
[2021-08-31 05:07:42.417 11828M] Resizing "FTL-dns-cache" from 36864 to (2560 * 16) == 40960 (/dev/shm: 2.1MB used, 517.6MB total, FTL uses 2.1MB)
[2021-08-31 05:26:09.092 11828M] Resizing "FTL-queries" from 1572864 to (28672 * 64) == 1835008 (/dev/shm: 2.1MB used, 517.6MB total, FTL uses 2.1MB)
[2021-08-31 05:45:42.469 11828M] Resizing "FTL-dns-cache" from 40960 to (2816 * 16) == 45056 (/dev/shm: 2.4MB used, 517.6MB total, FTL uses 2.4MB)
[2021-08-31 07:13:12.141 11828M] Resizing "FTL-queries" from 1835008 to (32768 * 64) == 2097152 (/dev/shm: 2.4MB used, 517.6MB total, FTL uses 2.4MB)
[2021-08-31 07:18:27.800 11828M] Resizing "FTL-dns-cache" from 45056 to (3072 * 16) == 49152 (/dev/shm: 2.7MB used, 517.6MB total, FTL uses 2.7MB)
[2021-08-31 07:57:19.030 11828M] Resizing "FTL-dns-cache" from 49152 to (3328 * 16) == 53248 (/dev/shm: 2.7MB used, 517.6MB total, FTL uses 2.7MB)
[2021-08-31 07:57:22.257 11828M] Resizing "FTL-strings" from 81920 to (122880 * 1) == 122880 (/dev/shm: 2.7MB used, 517.6MB total, FTL uses 2.7MB)
[2021-08-31 08:02:34.756 11828M] Resizing "FTL-domains" from 36864 to (2048 * 24) == 49152 (/dev/shm: 2.7MB used, 517.6MB total, FTL uses 2.7MB)
[2021-08-31 08:02:35.127 11828M] Resizing "FTL-dns-cache" from 53248 to (3584 * 16) == 57344 (/dev/shm: 2.7MB used, 517.6MB total, FTL uses 2.7MB)
[2021-08-31 08:11:37.282 11828M] Resizing "FTL-dns-cache" from 57344 to (3840 * 16) == 61440 (/dev/shm: 2.7MB used, 517.6MB total, FTL uses 2.7MB)
[2021-08-31 08:58:57.935 11828M] Resizing "FTL-queries" from 2097152 to (36864 * 64) == 2359296 (/dev/shm: 2.7MB used, 517.6MB total, FTL uses 2.7MB)
[2021-08-31 09:04:36.879 11828M] Resizing "FTL-dns-cache" from 61440 to (4096 * 16) == 65536 (/dev/shm: 3.0MB used, 517.6MB total, FTL uses 3.0MB)
[2021-08-31 09:06:03.414 11828M] Resizing "FTL-dns-cache" from 65536 to (4352 * 16) == 69632 (/dev/shm: 3.0MB used, 517.6MB total, FTL uses 3.0MB)
[2021-08-31 09:38:54.787 11828M] Resizing "FTL-queries" from 2359296 to (40960 * 64) == 2621440 (/dev/shm: 3.0MB used, 517.6MB total, FTL uses 3.0MB)
[2021-08-31 09:47:39.939 11828M] Resizing "FTL-dns-cache" from 69632 to (4608 * 16) == 73728 (/dev/shm: 3.3MB used, 517.6MB total, FTL uses 3.3MB)
[2021-08-31 10:21:36.017 11828M] Resizing "FTL-dns-cache" from 73728 to (4864 * 16) == 77824 (/dev/shm: 3.3MB used, 517.6MB total, FTL uses 3.3MB)
[2021-08-31 10:21:41.046 11828M] Resizing "FTL-queries" from 2621440 to (45056 * 64) == 2883584 (/dev/shm: 3.3MB used, 517.6MB total, FTL uses 3.3MB)
[2021-08-31 10:27:11.408 11828M] Resizing "FTL-dns-cache" from 77824 to (5120 * 16) == 81920 (/dev/shm: 3.5MB used, 517.6MB total, FTL uses 3.5MB)
[2021-08-31 10:46:49.391 11828M] Resizing "FTL-dns-cache" from 81920 to (5376 * 16) == 86016 (/dev/shm: 3.5MB used, 517.6MB total, FTL uses 3.5MB)
[2021-08-31 10:50:31.170 11828M] Resizing "FTL-dns-cache" from 86016 to (5632 * 16) == 90112 (/dev/shm: 3.5MB used, 517.6MB total, FTL uses 3.5MB)
[2021-08-31 10:50:34.836 11828M] Resizing "FTL-domains" from 49152 to (2560 * 24) == 61440 (/dev/shm: 3.5MB used, 517.6MB total, FTL uses 3.5MB)
[2021-08-31 10:52:51.532 11828M] Resizing "FTL-dns-cache" from 90112 to (5888 * 16) == 94208 (/dev/shm: 3.6MB used, 517.6MB total, FTL uses 3.5MB)
[2021-08-31 10:54:54.997 11828M] Resizing "FTL-queries" from 2883584 to (49152 * 64) == 3145728 (/dev/shm: 3.6MB used, 517.6MB total, FTL uses 3.6MB)
[2021-08-31 17:59:18.449 19027M] Blocking status is enabled
[2021-08-31 17:59:18.451 19027/T19030] Listening on Unix socket
[2021-08-31 17:59:18.451 19027/T19029] Listening on port 4711 for incoming IPv6 telnet connections
[2021-08-31 17:59:18.451 19027/T19028] Listening on port 4711 for incoming IPv4 telnet connections
[2021-08-31 17:59:18.457 19027/T19031] Compiled 0 whitelist and 0 blacklist regex filters for 46 clients in 0.1 msec
[2021-08-31 18:00:18.089 19027M] Resizing "FTL-dns-cache" from 4096 to (512 * 16) == 8192 (/dev/shm: 5.3MB used, 517.6MB total, FTL uses 5.3MB)
[2021-08-31 18:04:29.162 19027M] Resizing "FTL-dns-cache" from 8192 to (768 * 16) == 12288 (/dev/shm: 5.3MB used, 517.6MB total, FTL uses 5.3MB)
[2021-08-31 18:05:06.055 19027M] Resizing "FTL-domains" from 61440 to (3072 * 24) == 73728 (/dev/shm: 5.3MB used, 517.6MB total, FTL uses 5.3MB)
[2021-08-31 18:11:07.860 19027M] Resizing "FTL-dns-cache" from 12288 to (1024 * 16) == 16384 (/dev/shm: 5.3MB used, 517.6MB total, FTL uses 5.3MB)
[2021-08-31 18:17:48.772 19027M] Resizing "FTL-dns-cache" from 16384 to (1280 * 16) == 20480 (/dev/shm: 5.3MB used, 517.6MB total, FTL uses 5.3MB)
[2021-08-31 18:18:54.198 19027M] Resizing "FTL-dns-cache" from 20480 to (1536 * 16) == 24576 (/dev/shm: 5.3MB used, 517.6MB total, FTL uses 5.3MB)
[2021-08-31 18:36:48.990 19027M] Resizing "FTL-queries" from 4718592 to (77824 * 64) == 4980736 (/dev/shm: 5.3MB used, 517.6MB total, FTL uses 5.3MB)
[2021-08-31 18:44:04.931 19027M] Resizing "FTL-dns-cache" from 24576 to (1792 * 16) == 28672 (/dev/shm: 5.6MB used, 517.6MB total, FTL uses 5.6MB)
[2021-08-31 19:09:39.885 19027M] Resizing "FTL-dns-cache" from 28672 to (2048 * 16) == 32768 (/dev/shm: 5.6MB used, 517.6MB total, FTL uses 5.6MB)
[2021-08-31 19:16:47.669 19027M] Resizing "FTL-queries" from 4980736 to (81920 * 64) == 5242880 (/dev/shm: 5.6MB used, 517.6MB total, FTL uses 5.6MB)
[2021-08-31 19:24:39.661 19027M] Resizing "FTL-dns-cache" from 32768 to (2304 * 16) == 36864 (/dev/shm: 5.9MB used, 517.6MB total, FTL uses 5.9MB)
[2021-08-31 19:33:04.557 19027M] Resizing "FTL-dns-cache" from 36864 to (2560 * 16) == 40960 (/dev/shm: 5.9MB used, 517.6MB total, FTL uses 5.9MB)
[2021-08-31 19:54:35.141 19027M] Resizing "FTL-dns-cache" from 40960 to (2816 * 16) == 45056 (/dev/shm: 5.9MB used, 517.6MB total, FTL uses 5.9MB)
[2021-08-31 20:25:07.783 19027M] Resizing "FTL-dns-cache" from 45056 to (3072 * 16) == 49152 (/dev/shm: 5.9MB used, 517.6MB total, FTL uses 5.9MB)
[2021-08-31 20:26:54.480 19027M] Resizing "FTL-domains" from 73728 to (3584 * 24) == 86016 (/dev/shm: 5.9MB used, 517.6MB total, FTL uses 5.9MB)
[2021-08-31 20:28:34.414 19027M] Resizing "FTL-dns-cache" from 49152 to (3328 * 16) == 53248 (/dev/shm: 5.9MB used, 517.6MB total, FTL uses 5.9MB)
[2021-08-31 20:31:21.058 19027M] Resizing "FTL-dns-cache" from 53248 to (3584 * 16) == 57344 (/dev/shm: 5.9MB used, 517.6MB total, FTL uses 5.9MB)
[2021-08-31 20:34:30.937 19027M] Resizing "FTL-strings" from 122880 to (163840 * 1) == 163840 (/dev/shm: 5.9MB used, 517.6MB total, FTL uses 5.9MB)
[2021-08-31 20:45:39.940 19027M] Resizing "FTL-dns-cache" from 57344 to (3840 * 16) == 61440 (/dev/shm: 6.0MB used, 517.6MB total, FTL uses 5.9MB)
[2021-08-31 20:46:56.279 19027M] Resizing "FTL-queries" from 5242880 to (86016 * 64) == 5505024 (/dev/shm: 6.0MB used, 517.6MB total, FTL uses 5.9MB)
[2021-08-31 21:07:50.972 19027M] Resizing "FTL-dns-cache" from 61440 to (4096 * 16) == 65536 (/dev/shm: 6.2MB used, 517.6MB total, FTL uses 6.2MB)
[2021-08-31 21:26:29.360 19027M] Resizing "FTL-dns-cache" from 65536 to (4352 * 16) == 69632 (/dev/shm: 6.2MB used, 517.6MB total, FTL uses 6.2MB)
[2021-08-31 21:51:37.457 19027M] Resizing "FTL-dns-cache" from 69632 to (4608 * 16) == 73728 (/dev/shm: 6.2MB used, 517.6MB total, FTL uses 6.2MB)
[2021-08-31 22:10:10.806 19027M] Resizing "FTL-dns-cache" from 73728 to (4864 * 16) == 77824 (/dev/shm: 6.2MB used, 517.6MB total, FTL uses 6.2MB)
[2021-08-31 22:17:02.637 19027M] Resizing "FTL-queries" from 5505024 to (90112 * 64) == 5767168 (/dev/shm: 6.2MB used, 517.6MB total, FTL uses 6.2MB)
[2021-08-31 22:23:07.550 19027M] Received: Real-time signal 0 (34 -> 0)
[2021-08-31 22:23:08.296 19027/T19031] Compiled 0 whitelist and 0 blacklist regex filters for 52 clients in 0.1 msec
[2021-08-31 22:23:30.139 19027M] Received: Real-time signal 0 (34 -> 0)
[2021-08-31 22:23:30.328 19027/T19031] Compiled 0 whitelist and 0 blacklist regex filters for 52 clients in 0.1 msec
[2021-08-31 22:23:48.358 19027M] Resizing "FTL-dns-cache" from 77824 to (5120 * 16) == 81920 (/dev/shm: 6.5MB used, 517.6MB total, FTL uses 6.5MB)
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 pihole pihole 356352 Aug 31 19:16 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 224 Aug 31 17:59 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 81920 Aug 31 17:59 /dev/shm/FTL-dns-cache
-rw------- 1 pihole pihole 86016 Aug 31 22:10 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 48 Aug 31 22:02 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 8192 Aug 31 17:59 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 4096 Aug 31 17:59 /dev/shm/FTL-per-client-regex
-rw------- 1 pihole pihole 5767168 Aug 31 17:59 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 12 Aug 31 17:59 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 163840 Aug 31 22:04 /dev/shm/FTL-strings
-rw------- 1 pihole pihole 20480 Aug 31 17:59 /dev/shm/FTL-upstreams
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
*** [ DIAGNOSING ]: Locale
LANG=
-rw-r--r-- 1 pihole pihole 45981933 Aug 31 22:25 /var/log/pihole.log
-----head of pihole.log------
Aug 31 00:00:02 dnsmasq[11828]: query[type=65] weather-data.apple.com from 10.0.0.91
Aug 31 00:00:02 dnsmasq[11828]: forwarded weather-data.apple.com to 8.8.4.4
Aug 31 00:00:02 dnsmasq[11828]: query[A] weather-data.apple.com from 10.0.0.91
Aug 31 00:00:02 dnsmasq[11828]: reply weather-data.apple.com is <CNAME>
Aug 31 00:00:02 dnsmasq[11828]: reply weather-data.apple.com.akadns.net is <CNAME>
Aug 31 00:00:02 dnsmasq[11828]: reply weather-data.apple.com.akamaized.net is <CNAME>
Aug 31 00:00:02 dnsmasq[11828]: reply a2047.dscb.akamai.net is 24.200.0.169
Aug 31 00:00:02 dnsmasq[11828]: reply a2047.dscb.akamai.net is 24.200.0.162
Aug 31 00:00:02 dnsmasq[11828]: reply a2047.dscb.akamai.net is 24.200.0.171
Aug 31 00:00:02 dnsmasq[11828]: reply a2047.dscb.akamai.net is 24.200.0.176
Aug 31 00:00:02 dnsmasq[11828]: reply a2047.dscb.akamai.net is 24.200.0.170
Aug 31 00:00:02 dnsmasq[11828]: reply a2047.dscb.akamai.net is 24.200.0.160
Aug 31 00:00:02 dnsmasq[11828]: reply a2047.dscb.akamai.net is 24.200.0.163
Aug 31 00:00:02 dnsmasq[11828]: reply a2047.dscb.akamai.net is 24.200.0.161
Aug 31 00:00:02 dnsmasq[11828]: reply a2047.dscb.akamai.net is 24.200.0.168
Aug 31 00:00:02 dnsmasq[11828]: query[type=65] a2047.dscb.akamai.net from 10.0.0.91
Aug 31 00:00:02 dnsmasq[11828]: forwarded a2047.dscb.akamai.net to 8.8.4.4
Aug 31 00:00:02 dnsmasq[11828]: query[A] a2047.dscb.akamai.net from 10.0.0.91
Aug 31 00:00:02 dnsmasq[11828]: cached a2047.dscb.akamai.net is 24.200.0.168
