Click.redditmail.com and thirdparty.bnc.lt both whitelisted, but still unable to click through to thread from email
Clicking through from Reddit's email digest should take me to the associated thread. Both URLs in the CNAME/Redirect path have been whitelisted manually and gravity has been updated.
Attempting to click through results in me landing on Firefox's (ver. 88.0) "Hmm. We’re having trouble finding that site." page. In Chromium browsers (Brave Version 1.23.75 Chromium: 90.0.4430.93), this manifests as a DNS_PROBE_POSSIBLE error. The query log returns a Blocked (gravity) result when attempting to access the page.
I've tried removing it from the GUI whitelist and adding it via SSH using pihole -w click.redditmail.com and pihole -w thirdparty.bnc.lt and updating gravity immediately after via SSH. I cleared my local Windows DNS cache with ipconfig /flushdns. Still no luck.
Running an nslookup results in a response from the pihole, with the addresses being set to the default interface :: and 0.0.0.0 for IPv6/4 respectively, which is expected if the site is getting blackholed by gravity.
My Pi-hole is being hosted on my QNAP TS-251+ in an Ubuntu 18.04 LTS LXC via QNAP's Container Station, kernel ver 4.14.24-QNAP x86-64. Pi-hole is running ver. 5.3.1, web 5.5, ftl 5.8.1
https://tricorder.pi-hole.net/4pdca1gyfc
EDIT: Fixing a couple words.
I think you have your groups confused.
*** [ DIAGNOSING ]: Groups
   id    enabled  name                                                date_added           date_modified        description
   0           1  Pihole Bypass                                       2021-04-22 16:14:16  2021-04-22 16:21:03  The default group
   3           1  Pihole Users                                        2021-04-22 16:21:17  2021-04-22 16:21:17  Devices that use Pi-hole
   id    type  enabled  group_ids     domain        date_added           date_modified        comment
   308   0           1  0             click.redditmail.com        2021-05-04 22:28:04  2021-05-04 22:28:04  Added from Query Log
Maybe I'm just blind but on the web interface I'm not seeing a way to set which groups a specific whitelisted domain is applied to. Or does it just always apply to the first group?
http://pi.hole/admin/groups-domains.php
Yup I’m just blind. Thanks for pointing me in the right direction haha. Solved.
