Access Pi-hole web gui http://ip:port
Getting "ERR_CONNECTION_REFUSED" when trying to connect.
Debug Token and other outputs:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] 01-resolver-resolv: applying...
[fix-attrs.d] 01-resolver-resolv: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 20-start.sh: executing...
::: Starting docker specific checks & setup for docker pihole/pihole
[i] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf...
[✓] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
Configuring default DNS servers: 8.8.8.8, 8.8.4.4
Custom WEB_PORT set to 8080
INFO: Without proper router DNAT forwarding to 0.0.0.0:8080, you may not get any blocked websites on ads
[✓] New password set
DNSMasq binding to default interface: eth0
Added ENV to php:
"PHP_ERROR_LOG" => "/var/log/lighttpd/error.log",
"ServerIP" => "0.0.0.0",
"VIRTUAL_HOST" => "0.0.0.0",
Using IPv4 and IPv6
::: setup_blocklists now setting default blocklists up:
::: TIP: Use a docker volume for /etc/pihole/adlists.list if you want to customize for first boot
::: Blocklists (/etc/pihole/adlists.list) now set to:
::: Testing pihole-FTL DNS: FTL started!
::: Testing lighttpd config: Syntax OK
::: All config checks passed, cleared for startup ...
::: Enabling Query Logging
[i] Enabling logging...
[✓] Logging has been enabled!
::: Docker start setup complete
kill: usage: kill [-s sigspec | -n signum | -sigspec] pid | jobspec ... or kill -l [sigspec]
Pi-hole version is v5.3.1 (Latest: v5.3.1)
AdminLTE version is v5.5 (Latest: v5.5)
FTL version is v5.8.1 (Latest: v5.8.1)
[cont-init.d] 20-start.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
Starting lighttpd
Starting pihole-FTL (no-daemon) as root
Starting crond
[services.d] done.
I have added the "WEB_PORT" env variable to get it to work, and exposed port 80 as 8080.
Not sure what I'm doing wrong. This setup has worked on earlier versions.
version: "3"
services:
pihole:
container_name: pihole
image: pihole/pihole:dev
ports:
- "53:53/tcp"
- "53:53/udp"
- "67:67/udp"
- "8080:80/tcp"
- "2083:443/tcp"
environment:
TZ: 'Europe/London'
WEB_PORT: 8080
WEBPASSWORD: 'Test9900++'
volumes:
- './etc-pihole/:/etc/pihole/'
- './etc-dnsmasq.d/:/etc/dnsmasq.d/'
cap_add:
- NET_ADMIN
restart: unless-stopped
