Hi, i am running pihole on my homebridge raspi4. Everything works fine, but i can't open the pihole webUI.
via IP -> homebridge webUI opens
via IP:80 -> homebridge webUI opens as well
homebridge is set to listen on port 8080.
The newest versions of both applications are installed. Both work fine - except for the problem above...
You probably have another web server running on your machine.
[✗] tcp:0.0.0.0:80 is in use by nginx (https://docs.pi-hole.net/main/prerequisites/#ports)
[✗] tcp:[::]:80 is in use by nginx (https://docs.pi-hole.net/main/prerequisites/#ports)
You need to change nginx port to something else.
Alternatively you can configure nginx to run Pi-hole web interface or simply disable nginx.
