Hello, I'm running a small webserver on a Pi listening to port 80.
Now I wanted to test Pi-hole and saw that it also uses port 80.
As I've seen in different posts here, changing default port 80 to for example 8080 in lighttpd.conf could be a solution, but definitely not recommended because:
- any upgrade of pi-hole will overwrite lighttpd.conf settings and change the port back to default
- the block-page and transparent pixel will not be served in response to ads, and sites will take long time to finish loading if pi-hole isn't listening to specifically port 80
So came Docker to my mind, I'm new to it and only played with a few containers. Fortunately there is an official pi-hole docker image.
I was wondering, would mapping a different port for the host but keeping port 80 for the container works even for 1. and 2.? So like this (command shortened):
docker run -d --name pihole -p 8080:80 -p 443:443 -p 53:53/tcp -p 53:53/udp
I'm pretty confident for 1. but don't know how I can test for 2.
EDIT:
After several test it's not possible.
Also didn't pay attention enough but the readme mention it too:
You can still map other ports to Pi-hole port 80 using docker's port forwarding like this
-p 8080:80
, but again the ads won't render properly. Changing the inner port 80 shouldn't be required unless you run docker host networking mode.
source: docker-pi-hole/README.md at master · pi-hole/docker-pi-hole · GitHub
