Can't Install Pi-hole on CentOS 8 Stream (Installation Stuck)
Hello,
I use CentOS 8 Stream at Hetzner. Verbose output is attached.
The installation script can not proceed and stuck after "Root user check" even if it is a root user.
Can you help please?
Best regards
Verbose.txt (4.7 KB)
Known bug, will be fixed in the next release.
To mitigate see here
https://github.com/pi-hole/pi-hole/issues/3947
Hello,
Thank you for your reply. I will wait for the next release now. Hope it will come soon.
Regards
