I've been struggling with this for a while and I'm going around in circles it seems!
So - the setup is:
clients -> pihole -> router (DHCP) -> modem -> internet
192.168.1.x
I have the pihole sending requests to the router (which is DHCP) and an internal other DNS server (Domain Controller). The DHCP/Router is listed first in the DNS settings of the pihole.
I've disabled both of the pihole settings to do with reverse look ups:
never forward non-FQDNs
never forward reverse lookups for private IP ranges
When I do a reverse lookup of an IP directly using nslookup against the router, it gives me an address:
[root@pihole log]# nslookup
> server 192.168.1.1
Default server: 192.168.1.1
Address: 192.168.1.1#53
> 192.168.1.157
Server: 192.168.1.1
157.1.168.192.in-addr.arpa name = amazon-1b9d96726.local.domainname.tld.
However, when I do this to the pihole, I don't get a response:
> 192.168.1.157
Server: 192.168.1.8
Address: 192.168.1.8#53
** server can't find 157.1.168.192.in-addr.arpa.: NXDOMAIN
BUT this is showing the secondary dns server, not the router, wtf.
So, I tried adding a 10-lan-domain.conf:
[root@pihole dnsmasq.d]# cat 10-lan-domain.conf
server=/local.domainname.tld/192.168.1.1
server=/1.168.192.in-addr.arpa/192.168.1.1
but still no dice.
I've tried removing all of the pihole log files, and the FTL database, and restarting FTL, but you see the FTL log show clients appearing without name resolution.
For various reasons, I don't want the Pihole to be the DHCP server.
Debug log; licipjl8zs
